My new triple light, The Beast!!!!- Mtbr.com
Results 1 to 20 of 20
    Spanish biker
    Reputation: msxtr's Avatar
    ... and if we just ... My new triple light, The Beast!!!!
    Hi, here my new triple light, very, very easy of doing, how you can see, I hope that like us
    I have used a square tuve of 40x40mm and PVC tube of external diameter of 40x40mm too.
    Now glued the PVC tubes to the aluminium tube
    Inside view, I have used too a "custom" inside heatsink how you can see
    Glued the 3 leds to the aluminium tube (I have used 2 Cree Q5 and 1 Cree P4, I know that have was better use R2 leds, but was that I had )
    I make holes in the square tube and I have soldered the cables...
    Now I have solder the cables to the swich, drivers and power conection, I have used 3 drivers to can use a battery of only 7,4 volts
    Another view
    Rear view
    Another view
    Power supply put on the tube
    Inside view
    Switch put on the tube
    Inside view
    I have isolated the driver with....(sorry, but I don't know how it say in english "manguera termoretractil")
    Another view
    Another upper view
    Bottom view, I have used a H-24 spacer from Cateye
    Front view
    Well, I still don't have ended the light, already don't have put the lateral caps, but I hope ended soon and put any beamshot
    Greetings - Saludos
    msxtr
    Warning!!! my english is very very bad, sorry.
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    What no beamshots from the guy who always request beamshots? How dare you.
    Looks good
    Spanish biker
    Quote Originally Posted by scar
    Looks good
    hehehe, I don't have had time yet!!!! soon will have beamshots...I hope...
    Greetings - Saludos
    msxtr
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    kennan drivers...
    Those look like Kennan drivers. What are you powering them w/? I've had 3 die on me...I miss the old design.
    Spanish biker
    Quote Originally Posted by cytoe
    Yes, are the "new" kennan drivers
    And I have used this drivers in several DIY lights and work perfectly....I use a Li-Ion battery of camcorder of 7,4 volts to powering...
    I had a "old" kennan driver and die too....I think that this drivers are better do than the olds...
    Greetings - Saludos
    msxtr
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    Cool! Thanks for the detailed pics.
    thats some big a$$ optics you got there! lets see some beamshots
    What are those optics and come on
    WE WANT BEAM SHOTS
    Reputation: yetibetty's Avatar
    Nice big 35mm? optics and individual drivers, it should be nice and bright.
    Another request for beam shots please, outside on the trail would be nice.
    manguera termoretractil = Heat shrink
    Beamshots Please
    Spanish biker
    Hi, ok, ok, soon I try do the beamshots..by the night
    yetibetty yes are 35mm optics. Thanks for the translation to english
    troutie-mtb, the optics are from dealextreme, are these
    Greetings - Saludos
    msxtr
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    It Is Dark Now
    Beamshots :d
    Spanish biker
    Quote Originally Posted by troutie-mtb
    It Is Dark Now
    Beamshots :d
    Hi, dark, where? I am from Spain now are 21:20 H...
    First beamshot on the wall, this is about 50 meters.
    Control
    Beamshot
    Greetings - Saludos
    msxtr
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    that is bright
    can you switch 2 lights off and do a shot with just 1 , then 2 , and we have seen 3 .
    Nice work
    Thanks for the beams, very nice.
    Reputation: Batas's Avatar
    Heat Shrink Tube.
    Spanish biker
    that is bright
    Nice work
    For now I think that will use the light only with 1 switch to all leds, maybe that in the future I change the configuration to switch 1, 2 and the 3 leds...
    Now beamshot in the country
    Greetings - Saludos
    msxtr
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    Nice Pic a very usable beam maybe it could do with an optic swapping for a flood to fill in the near ground .
    Spanish biker
    Hi, I normally use too another light with more flood beam, with the both lights I get a excellent beam of near and far
    Greetings - Saludos
    msxtr
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    Reputation: MaximusHQ's Avatar
    Looks great! Good Job.
