Is my maxflex from cutter shagged???- Mtbr.com
Results 1 to 7 of 7
    I got my maxflex the other day from Cutter and on closer inspection, the bottom left corner looks a little munted. Is this likely to be a problem? I'll try to attach a picture....
    aka RossC
    Reputation: ocean breathes salty's Avatar
    I don't know definitively, but it looks like it breaks the circuit coming from Q2. So I would suspect that is one dead maxflex. Bummer!
    If you have a meter with resistance or continuity you should be able to tell if the track is good or not.
    Ifor
    Reputation: HuffyPuffy's Avatar
    Even if it does work, it looks a bit close. Would really suck to have that sealed up in a light only to have it fail on a ride. Do you think it happened in shipping? I would ask for another or repair it with some small wire to bridge over the trace.
    Reputation: HEY HEY ITS HENDO's Avatar
    the boards are manufactured, programmed and shipped in strips
    the perforations are where they are joined together
    you can see the break from the adjoining board has not been a clean snap
    dont repair it, have it replaced, they aren`t cheap are they!!
    ...Scun.thorpe, UK
    Please return for replacement
    Cheers
    WeLight
    Cutter Electronics Pty Ltd www.cutter.com.au
    Cheers Welight. I'll pop it in the post with covering letter
    ant
