My Light is doing my head in- Mtbr.com
Results 1 to 10 of 10
    Hi All
    My lights are doing my head in. i have built and used 1 and now im building my second. the thing that gets me is im using 1050mA drivers but my lights aren't as bright as some of the others getting around, i have tried checking the driver output with my DMM but im not sure if im doing it correctly. Its only reading 0.1 when on the 10A setting, is this correct? it also drops really fast within a couple of minutes it had gone as low as 0.08, ill take some pics of what im doing tonight to see if anyone here can help shed some light on this for me. Im thinking about getting a 750mA driver from cutter to see if this works any better. Im running CREE R2 and Q5 LED's in different lights but they just aren't bright enough.
    Thanks in advance
    Josh
    Reputation: znomit's Avatar
    Josh could you post pics and more details of your setup. It would help diagnose any issues. Its not clear in the other thread what exactly you went with. If you are using the 30 degree optics your light will be far to spread out to throw a bright spot.
    It may well be dud DX drivers, or wired wrong(driver or meter)
    In general a good dual Q5/R2 setup running at 1A is enough to ride fast on familiar trails and handle anything on the road.
    ok well i think i had a dud driver for the first test. have a look at the pics below. Im running 3-2450mAh 1.2V energizers for the test rig with a 12mm Alloy heat sink.
    Batery voltage at full charge
    Driver wiring
    First driver test
    Second driver test
    Between the first and second test even the colour of the light that is being put out is different. the light that i have now is awesome, nearly they same as my mates Ay-ups ill get one of there's for a comparison shot in the next few days.
    I think some new optics from Cutter will have to be ordered tomorrow.
    I'm excited again
    Reputation: HuffyPuffy's Avatar
    Good thing those drivers are cheap, makes it less painful when one is lost Looks like you have quite a few to spare though.
    that one of the DX "Mystery" hobby chargers in the silver case - and if so, how do you like it?
    yes it is a Mystery charger I bought it off ebay a few years ago. it seams to do an ok job I spose. It does it's job and charges my batteries. no complaints really.
    hey guys,
    1 last question before i try and stuff everything into my housing. can i run 2 drivers off the 1 battery pack?
    Quote Originally Posted by Joshp82
    hey guys,
    Yes.
    Awesome thanks. I tested the draw from the battery to the driver and it was 970mA to each driver. Is that the amount I need to work out the run time of my battery pack? Each driver puts out 1050mA, already i can notice the difference between this light and my other one. this one gets hotter quicker. i might need to add some heat sink fins to the top
    all i can say is WOW, these new drivers are awesome. the light is so clean and white. i only went for a short ride tonight, but the new light over my first one is amazing. i will test it out in the Bush over the next few days. all i need now is to figure out a bar mount
    hello again, I have a question about run times.
    I did a draw test infront of the driver and 1.30A are being drawn
    If im using 2450mAh batteries will I get just short of 2 hours run time?
    I rode for 1h15mins last night and i didn't notice any drop in light.
    Im also pleased to say my $60 DIY light is brighter than a $275 Ayup
