My Find .... Pod for Storing Batteries using Water Bottle Cage- Mtbr.com
Results 1 to 6 of 6
    acg
    acg is offline
    I am a newbie to MTBR.com and I do not recollect this being mentioned anywhere.... just thought I pass this around...
    I was shopping for Christmas at REI and came across this unique water-proof pod which fits into a standard water-bottle cage:
    http://www.rei.com/product/776187
    It has a wide flip cover at the top which would allow DIY batteries to be easily inserted into the carrier. I plan to use this pod to hold DIY replacement batteries to power up my Niterider Flight HID system. I will be drilling a small hole for the wires to be routed out of the bottle. The hole will then be sealed up with some silicone.
    I hope this will be useful for you DIY'ers!
    Cheers,
    Andrew
    Thanks for posting acg. Looks a good idea, although seems a bit expensive compared with a standard water bottle, which is also waterproof. You can get water bottles that have a big top and would be equally good for storing tools like the rei pod.
    acg
    acg is offline
    I tried the regular water bottle with the wide mouth. Unfortunately, my battery pack replacement pack is mounted as three 18650 batteries side-by-side which makes it difficult to get through the mouth of a water bottle. This REI pod was a great solution for me
    BBB Tool Can - cheap & simple (& waterproof):
    http://forums.mtbr.com/showpost.php?...5&postcount=20
    Quote Originally Posted by acg
    Aha, hadn't appreciated that. In that case its a good find, thanks for posting
    Quote Originally Posted by klynk
    Think I'll get one of those if only to get my spare tube and tools into a more accessible place than my camelbak. Thanks
    Dirt Deviant
    Reputation: savagemann's Avatar
    Good find.
    I had this in mind for a battery storage container.............
    http://www.cleanbottle.com/
    Look, whatever happens, don't fight the mountain.
