Modifying a Yinding (or similar) to a comfortable headlamp- Mtbr.com
Results 1 to 5 of 5
    Feb 2010
    Yinding seems to be a nearly perfect headlamp but the handling isn't very comfortable.
    At BG I found a wireless Dimmer, Gb sells it too iirc.
    The idea, building a battery pack with dimmer as driver:
    - 2 NCR1650B or whatever you like
    - 2S PCM
    - 1 stripped wireless LED Dimmer
    Neoprene, sewing machine and so on for working out a fine holster
    Receiver - Dimmer/Driver replacement
    Transmitter
    The driver inside the YD should be disabled so you can enjoy the full potential of the dimmer.
    Nov 2012
    Still the box is a bit large - 10cm I like the idea going wireless even if you have to maintain another battery in the transmitter. OTOH I need about 20-30cm cable to make a propoer wired remote switch and maybe going this wireless way is not convenient for me. Thanks for the tip anyway.
    Reputation: Ofroad'bent's Avatar
    Nice as the wireless remote idea is, it's not that hard to improve a Yinding for headlamp use.
    I replaced the driver in my Yinding with a 10-step programmable driver from KD.
    I can now program 3 lower levels for running, and it's easy to reprogram on the fly.
    I also swapped the mount for one of Vancbiker's GoPro adpapters, and use a nice GoPro headband.
    I may use one as a shell and do see if I can get a decent driver and switch in there in a future build.
    Feb 2010
    Quote Originally Posted by MK96 View Post
    The PCB is much shorter, somehow like a 18650, that's the trick.
    I was on the way to build something of my own, with that solution I mustn't waste my time. I only need a practicle idea for the transmitter on the bar.
    Batts are on the way, I hove they will arrive...
    Nov 2012
    Still quite big for me Share your thoughts when you finish the upgrade
  1. How to replace the LEDs in my Yinding
    By TiGeo in forum Lights DIY - Do It Yourself
    Last Post: 12-20-2014, 05:52 AM
  2. MS 808/Yinding/SS X2/SS X3 comparo/info/photos
    By TiGeo in forum Lights and Night Riding
    Last Post: 07-23-2014, 12:10 PM
  3. Yinding + Solarstorm X2 combo ride report
    Last Post: 07-11-2014, 06:19 AM
  4. Double o-rings for Yinding?
    Last Post: 06-25-2014, 08:49 AM
  5. Yinding sources
    By carguy4471 in forum Lights and Night Riding
    Last Post: 04-24-2014, 01:29 PM
