Modification of a standard flishlight- Mtbr.com
Results 1 to 2 of 2
    Jan 2009
    Hello all
    Last year I baught a Flashlight. On the package, it is specified LED 3 W and works with 3 cells AAA (Diameter 6 mm). (25 € chez Décat).
    See hereafter picture.
    Fews days ago, I tryed to put inside a Li cell (18650). But since this test, the light don't work any more
    So, I openned it and removed out the electronic part. I was surprised : It is only a CMS resistor.
    I did tests and in fact, the resistor is dead and the led is OK
    Now, I am interesting in modify it and put inside an 18650 cell + a circuit board.
    Do you have any circuit board to suggest to me ?
    FIY, the led is a ZLED from SEOUL 3 W. On the DS, it works with 1000 mA,
    Inside, I can put a board with a maximum diamter of 26 mm.
    And the cell is a 18660 (3,7-4,2 V)
    In advance thank you,
    Djipe
    Jan 2009
    On Dealextrem, I've seen this driver :
    5-Mode 1000mA 7135 Circuit Board for Cree and SSC Emitters
    http://www.dealextreme.com/details.dx/sku.6190
    Do anybody had used it ?
    There is 2 wires. How do we plug it ? Have we to put an other wire for the switch ?
    Or do we use the on-off switch to change the 5 modes ?
    In advance thank you for your anwsers
