MCE and 14.8 volt lithium battery. Driver?- Mtbr.com
Results 1 to 7 of 7
    Dec 2008
    I have a 14.8 volt, 4 amp hour lithium battery and I want to run a MCE led. The parts will all be from cutter, I intend to use their MR11 housing.
    The driver I want to use is the bFlex UIB2.
    The driver specifications say you need 1.1 volts over Vf. That puts it very close to the 14.8 volts of the battery (Vb).
    Has anyone used this combination and does it work? Will the battery voltage drop fairly quickly to below the desired Vf? I expect to be running 700mA, maybe more if I can get away with it.
    Please let me know your real world results, I don't want to order the parts if it's not going to work.
    While it's not real world results, 14.8 is 4 * 3.7 (typically called a 4s pack). The lithium ion batteries will drop slightly below 3.7V/cell pretty quickly, but will remain fairly stable throughout the rest of the discharge, reaching around 3.5V at 20% remaining capacity - http://www.buchmann.ca/chap2-page6.asp . Your battery's discharge curve may be different, but most lithium ion batteries have the same sort of characteristic.
    Treadly your lithium pack will be 16.8 off the charger and your MCE will most likely be under 13 volts with all dies in series.
    Loads of us on here have used your suggested set up with no problems at all
    aka RossC
    Reputation: ocean breathes salty's Avatar
    Quote Originally Posted by Treadly
    I have done it with a 4s MCE but it was using a buckpuck. It allegedly requires 2 V above Vf to stay in regulation but it has worked OK for me so far. My MCE showed approx. 12.3 Vf.
    May 2005
    I had the same concern as well. I decided to build my battery with 5 cells for a nominal 18.5V as seen in this thread
    http://forums.mtbr.com/showthread.php?t=501179
    Cree's spec sheet puts the Vf of the MC-E at 14V. I am sure that many come in less than that but it seems that keeping the battery voltage up will ensure the output stays regulated through the cell's entire range.
    Dec 2008
    I blew one of the LEDs on a MCE that I was playing with, after shorting it out I measured exactly 10 volts across three leds whilst running 1000 mA through it.
    So I guess that gives me a Vf of 3.33 volts per LED, with a total of 13.33 for a full MCE.
    Include the 1.1 volts and that takes it to...Ummm ...14.4333 volts.
    That's why I was after real world results.
    And buy another MCE and you get different numbers... Forward voltage changes from led to led.
