maxFlex settings for a single 3.7v 18650?- Mtbr.com
    Reputation: deesta's Avatar
    New question here. maxFlex settings for a single 3.7v 18650?
    Hi all
    I'm having a couple of problems with my rear light....it lights up fine then, after a short time, stops. I think it may be to do with the cutoff/voltage settings on the maxFlex. Has anyone used a single battery with a max? If so, what settings would you recommend?
    I'm running 3 x red XP-E LED's with V5 maxFlex
    Fully charged, the battery is 4.13v
    Cheers
    Steve
    At what current are you driving your LEDs? What's the cutoff set to? Measure the voltage of the battery when fully loaded before cutoff and also measure the current draw from the battery. Is the battery protected? What brand? Measure the voltage of the battery after the cutoff. Under load there will be voltage sag. How much depends on the internal resistance of the cell. Drain the battery to 3V when not under load and and set the cutoff to whatever measurement you get under load.
    maxflex need 2 cells,
    min 4V, single cell will not work
    Mine is a maxFlex v5 which will do 2.5V so no problem using a single cell.
    I'm not too sure how to check cut-off etc so, based on the pre-set cut off for 2 cells, I've set the cutoff @ 3.1v. All seems to be working properly now.
    I think the light was going into cutoff mode which, as I'd not set it right, would explain the problems..
    Thanks for the replies guys
