Looking to add some 5050 SMD LEDs to bike.- Mtbr.com
Results 1 to 3 of 3
    Nov 2015
    Has anyone ever added (the above) to their bike or something like it? I ride a motorcycle and am also in LE and I want to stick out at night. I already bought a handle bar mount that fits various 18650 flashlights I own and I also bought a decently bright rear tailight that's powered by 2x AAA.
    But what about side visibility? I'd like to buy a SMD 5050 LED light strip and wire them to a battery pack. Put several strip around the frame going long ways, not wrapping them around the frame literally.
    The light strip has a 3M backing but I bet I could get a magnet roll cut it to size and magnetically stick them on. Question is are their any 18650 battery packs that will power 30 to 40 SMD 5050 LEDs? And have some sort of UI where it knows the proper voltage etc?
    double thumbin' it!
    Yeah!
    Reputation: Flamingtaco's Avatar
    Mar 2012
    Yes. I bent some aluminum flat bar to go around my pannier and stuck the LED strip to that. Have done a lot of thinking about using 18650's to drive them, but the small 12V utility battery I use drives them fine and doesn't require a driver.
    The strips are designed for use without a driver and have resistors for each group of LED's. Don't need to current control if you stay below 14V
    I will suffer no butt-hurt fools!
    No talent hack
    Yup...
    My first trial run (more of a proof of concept):
    View My Video
    Second attempt (control module shorted a circuited while I was working with it. It should be flashing red and yellow like the first video):
    View My Video
    The control module is this, but you could use a different set up:
    http://www.amazon.com/Rigid-Industri...+strobe+module
    2018 Santa Cruz Hightower CC
    2014 Trek Domane 4.0
    2015 Surly Karate Monkey Ops (commuter, gravel, fun))
  1. Crank brothers 5050 pedals: dirt stuck in allan bolt heads
    By Hardtail Bryant in forum Components
    Last Post: 04-15-2017, 08:30 AM
  2. Needs some LEDs
    By BrianMc in forum Commuting
    Last Post: 06-19-2014, 02:10 PM
  3. best red leds?
    By car bone in forum Lights DIY - Do It Yourself
    Last Post: 05-10-2014, 07:36 AM
  4. Red leds
    By troutie-mtb in forum Lights DIY - Do It Yourself
    Last Post: 01-27-2013, 06:55 PM
  5. Crank Brothers 5050 pin problem ?
    By keen in forum Downhill - Freeride
    Last Post: 07-02-2011, 06:04 AM
