A literally cool Quazzle module housing- Mtbr.com
Results 1 to 38 of 38
    Based on my quad-MC-E housing I have drafted a housing for a Quazzle module.
    This is the Quad-MCE:
    And this is the 20mm prototype:
    Front
    Rear
    The bezel will be held by M3 screws, the cable hole is 3mm and the mount will use a M4 screw.
    I would like to hear your suggestions on this design.
    CNC LED light housing for DIY projects
    It would look better with round edges, IMHO.
    Those edges are rounded, R5mm. But maybe make them smaller?
    Quote Originally Posted by zemike
    Maybe only the upper ones.
    Reputation: Goldigger's Avatar
    Why make another one? just swap the 4 mce for 4 quazzle boards.. on paper 2800 vs 4400 lumens
    Plenty of cooling.....
    Guessing the MCE is a flood monster. What is the idea on the mount, and switch for the 20mm light.
    The Quad MCE is too big And it uses square optics.
    Quote Originally Posted by odtexas
    True, I used 20x40 optics.
    The mount can be almost everything where a M4 screw can be screwed.
    For the switch - a custom made remote switch.
    but I'll have to somehow squeeze the button cable into the housing.
    Also, maybe add a small cap on the top of the housing.
    This is the next version:
    I added a small cap over the top, mount for a silicone o-ring, moved the wire exit to the bottom of the body.
    The aluminum mount is compatible with Magicshine stuff.
    Reputation: Ofroad'bent's Avatar
    Looks great. Is there accommodation for a momentary switch?
    Quote Originally Posted by Ofroad'bent
    Unfortunately I was unable to find a waterproof small mom switch. The smallest is 16mm in diameter - huge for this housing.
    There is the possibility to use a remote button, shown in this topic.
    Have a look at these..i posted one on brads buils thread i think it was on his 7up thread
    http://www.rapidonline.com/Electroni...64/kw/Switches
    checked brads thread, same switch
    Goldigger
    This switch requires a cap. I was searching for something like that: http://www.rapidonline.com/Electroni...switches/81475
    but smaller
    Goldigger
    but smaller
    I have two of them ITW switches.. there as small as you can get..
    Unless you use the tactile type i linked to previously
    May 2005
    I used a tactile switch on my first MC-E light. It is the one that comes on a bflex driver. I mounted the driver so that the switch was flush to the bottom of a counterbore in the housing. I then used a thin piece of self adhering rubber sheet to make a cover disc to seal it. You just press through the rubber to actuate the switch. It works well with a bare finger or light glove. Heavy gloves make it difficult to use. All my subsequent bar lights have had remote switches.
    Quote Originally Posted by Vancbiker
    Good point. I also arrived to the same conclusion.
    Due to the fact that Mr. Quazzle lives in the same town as me, I can arrange a small batch of those housings kitted with the new L333 modules.
    Here are the front and rear views:
    Well, should I make the side fins smaller?
    Personally I would make the light longer and the fins less deep.. but that's just me..
    I bonded a tiny waterproof switch on the outside of my housing of my helmet lamp, and find it easier to work than the remote Batteryspace switch I have inline. It's not pretty though, sealed up with silicone- ideally the housing would have a detent for the switch to embed a bit.
    https://www.omron.com/ecb/products/pdf/en-b3sn.pdf
    I'd agree with the "longer and less deep fins" comment too.
    Do you mean that the bare wires are just covered in silicone? This is a tiny switch - is it comfortable with gloves?
    I was hoping to get liquid electrical tape to paint the solder connections, but after waiting forever for my order to show up, (never did, and I couldn't find it locally) I finally used 2 coats of black nail polish to insulate things then attached it with silicone, embedding the base.
    I also used silicone to seal the hole for the switch wires.
    The switch works fine with thick gloves- it's pretty sensitive.
    I ran the housing under running water as a test and the switch was fine.
    Ofroad'bent
    Can you post a photo of this setup? The button diameter is 3 mm!
    Found cheap waterproof pushbuttons: http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
    OK, here is a different version
    Longer, with shorter fins and space for a full-sized pushbutton or a cable gland.
    TOP
    FRONT
    REAR
    Both front and rear will have caps.
    Regarding the mount - which is preferrable: Cateye or Magicshine ?
    TOP
    FRONT
    REAR
    This thing will be so small and light, a simple L-bracket with some velcro would work as a helmet mount. I was planning on using my older Niterider tilt- mounts with mine, but the mount was massive compared with the little light.
    Cateye for a handlebar mount, no idea for helmet though. Bear in mind that the Cateye spacer is about 1 1/4in wide and 1 3/4-2in long, so I'm not sure how it'll fit with your housing. You can trim it down to 1in wide, not sure about the length.
    Reputation: bravellir's Avatar
    Nov 2008
    what about these?
    http://cgi.ebay.com/ebaymotors/12-Vo...Q5fAccessories
    Do you think they are mom or latch?
    Quote Originally Posted by bravellir
    what about these?
    Says 'push on, push off'. Must be latch IMO
    If your maching this yourself? how about making your own mount? maybe one that use the bolts on the clamp on your stem? they look dam cool..
    Ofroad'bent
    Here are some pics. Man, it looks fugly close up- I've got to trim some silicone off with a scalpel or razor.
    Works well though, and you can see the L-bracket. Chelboed's original bracket didn't tilt up enough for headband use.
    Nov 2008
    Quote Originally Posted by JezV
    tks
    Quote Originally Posted by Goldigger
    Yes, I will do the machining, so I can make the mounts as well. The problem with stem clamp mounts is the fact that they are restricted to specific stem models.
    So far the Magicshine mount is the simplest.
    I can also make housings for the upcoming Quazzle 7-up module with the same design.
    I assumed the light was for your own bike..
    True.
    But the machining shop refuses to make 1 housing
    Ofroad'bent
    Here's the light with the switch embedded in black gasket silicone. Looks a lot cleaner and more solid.
    Since you're still in design phase, may i contribute that a round light might look more handy and compact. Also, i suppose you could use 4 long screws instead of 8 short ones. Regarding the mounting options, as it will be a small and light, you should get the better mount for helmet use as it will be an excellent helmet light.....
    I'm Interested.
    Those fins actually do look really long .
    Quazzle's approach on helmet mounting would work and perhaps you could make a cross like pattern , where the lateral hinges would be used for helmet mounting and the axial for bar mounting. Of course, one pair will be recessed so that you can mount it on the bar.
    Yes, I am still in the design phase.
    Here is the round version:
    The only problem - the machine shop can't do this
    So I'm working on a totally different approach.
    And this is a concept of an orientable ultrasmall bar light:
    recognize the slowness
    Reputation: jbflyfshr's Avatar
    my .02 cents...
    for the round version, you could cut weight if you started with a round bar and just cut the same fins all the way round and drilled out the center for emitters and driver...could even make the fins more shallow toward the back for added space if you wanted to do a separate driver and light...also if I am not mistaken, thinner walls transfer heat better.
    Using the L333 this would be simpler not needing a tapered shape and any machine shop could accomplish that I think.
    JB
    "mountain biking and flyfishing, what more do you want?" - Yeah, I said it
    Quote Originally Posted by jbflyfshr
    my .02 cents...
    Initially that was my idea, but the machine shop charge a lot for this kind of machining.
    Currently I investigate another option - use an extruded round profile and have it turned on a lathe. This is much cheaper.
