Lion Air Batteries in the Pipeline- Mtbr.com
Results 1 to 7 of 7
    http://www.epsrc.ac.uk/PressReleases/oxlithbattery.htm
    Air-fuelled Battery Could Last Up to 10 Times Longer
    Issued: 18 May 2009
    A new type of air-fuelled battery could give up to ten times the energy storage of designs currently available.
    This step-change in capacity could pave the way for a new generation of electric cars, mobile phones and laptops.
    The research work, funded by the Engineering and Physical Sciences Research Council (EPSRC), is being led by researchers at the University of St Andrews with partners at Strathclyde and Newcastle.
    The new design has the potential to improve the performance of portable electronic products and give a major boost to the renewable energy industry. The batteries will enable a constant electrical output from sources such as wind or solar, which stop generating when the weather changes or night falls.
    Improved capacity is thanks to the addition of a component that uses oxygen drawn from the air during discharge, replacing one chemical constituent used in rechargeable batteries today. Not having to carry the chemicals around in the battery offers more energy for the same size battery. Reducing the size and weight of batteries with the necessary charge capacity has been a long-running battle for developers of electric cars.
    The STAIR (St Andrews Air) cell should be cheaper than today’s rechargeables too. The new component is made of porous carbon, which is far less expensive than the lithium cobalt oxide it replaces.
    This four-year research project, which reaches its halfway mark in July, builds on the discovery at the university that the carbon component’s interaction with air can be repeated, creating a cycle of charge and discharge. Subsequent work has more than tripled the capacity to store charge in the STAIR cell.
    Principal investigator on the project, Professor Peter Bruce of the Chemistry Department at the University of St Andrews, says: “Our target is to get a five to ten fold increase in storage capacity, which is beyond the horizon of current lithium batteries. Our results so far are very encouraging and have far exceeded our expectations.”
    The oxygen, which will be drawn in through a surface of the battery exposed to air, reacts within the pores of the carbon to discharge the battery. “Not only is this part of the process free, the carbon component is much cheaper than current technology,” says Bruce. He estimates that it will be at least five years before the STAIR cell is commercially available.
    The project is focused on understanding more about how the chemical reaction of the battery works and investigating how to improve it. The research team is also working towards making a STAIR cell prototype suited, in the first instance, for small applications, such as mobile phones or MP3 players.
    Notes for Editors
    The four-year research project “An O2 Electrode for a Rechargeable Lithium Battery” began on 1 July 2007 and is scheduled to end on 30 June 2011. It has received EPSRC funding of £1,579,137.
    Rechargeable lithium batteries are currently comprised of a graphite negative electrode, an organic electrolyte and lithium cobalt oxide as the positive electrode. Lithium is removed from the layered intercalation compound (lithium cobalt oxide) on charging and re-inserted on discharge.
    Energy storage is limited by the lithium cobalt oxide electrode (0.5 Li/Co, 130 mAhg-1). The University of St Andrews design replaces the lithium cobalt oxide electrode with a porous carbon electrode and allows Li+ and e- in the cell to react with oxygen from the air.
    Initial results from the project found a capacity to weight ratio of 1,000 milli-amp / hours per gram of carbon (mA/hours/g), while recent work has obtained results of up to 4,000 mA/hours/g. Although the two designs work very differently, this equates to an eight-fold increase compared to a standard cobalt oxide battery found in a mobile phone.
    The application to renewable energy could help get round the problems of intermittent supply. By discharging batteries to provide electricity and recharging them when the wind blows or sun shines, renewables become a much more viable option.
    The Engineering and Physical Sciences Research Council (EPSRC) is the UK’s main agency for funding research in engineering and the physical sciences. The EPSRC invests around £740 million a year in research and postgraduate training, to help the nation handle the next generation of technological change. The areas covered range from information technology to structural engineering, and mathematics to materials science. This research forms the basis for future economic development in the UK and improvements for everyone’s health, lifestyle and culture. EPSRC also actively promotes public awareness of science and engineering. EPSRC works alongside other Research Councils with responsibility for other areas of research. The Research Councils work collectively on issues of common concern via Research Councils UK. Website address for more information on EPSRC:
    For more information contact:
    The University of St Andrews visit: www.st-andrews.ac.uk
    Professor Peter Bruce FRS, tel: 01334 463 825, e-mail: [email protected]
    Three images are available from the EPSRC Press Office (contact: [email protected], tel: 01793 4514)
    Go faster!
    Reputation: sergio_pt's Avatar
    thats sounds good! I'll be waiting for the new high power batteries.
    Quoted from the article:
    "Improved capacity is thanks to the addition of a component that uses oxygen drawn from the air during discharge...".
    I wonder how they're going to solve the "Access to Oxygen" problem. What I mean by that is most devices utilized some kind of compartment or container for the cells. Some of these devices are pretty air tight. This would mean that any manufacturer wishing to use this battery technology would have to design the battery compartment with air flow in mind. Not a big problem for stuff not exposed to the outside elements. You could always put some kind of vents into the battery housing that would let air freely move around the batteries. For things like torches and bike lights.. ...
    Well...I suppose you could put vents into torches as long as you can isolate the electrical connections from the elements. I've got some ideas...maybe I'll patent them now and make a fortune..
    maker of trail
    Reputation: essenmeinstuff's Avatar
    O2 reacting with carbon sounds suspiciously familiar... wonder what happens when you charge it? Does it release O2? It can't just keep absorbing O2 for ever...
    You'd have to seal the battery for our purposes in a water tight container with enough oxygen to allow for the process I guess.
    For sealed battery units your going to likely have to remove a plug while charging to allow it the oxygen also.
    Still think on it, 18650 sized cell, powering 3 x MC-E ( be 1200lumens each by then hopefully ) on full for @4hours, or 1 for 12hours, ohhhh baby!!
    Go faster!
    They can include the oxygen in the battery and solve te problem of low to none air flow.
    They should have thought about that already.
    Don't worry and don't get too excited! The article doesn't mention the discharge rate of those batteries. They can have huge capacities at low, very low discharge rates (MP3s and cellphones) and very small capacity at high or medium rates (think of MC-E).
    I can mention a similar product - zinc-air cells, they are used in hearing aids.
