Li-ion for Niterider Storm- Mtbr.com
Results 1 to 2 of 2
    jkg
    jkg is offline
    Dec 2004
    I am trying to make/buy two more more batteries for my head light. I have read that an 11.1v Li-ion should work with my NiMH Storm, yes? Can I use the same charger it came with (I still want to use the original battery)? I see some cheap battery packs at all-battery.com http://www.all-battery.com/index.asp...OD&ProdID=1511, where can I find the shur-loks? Anything I should know to set this up?
    Couldn't find this info exactly on the forum.
    Thanks.
    Spanish biker
    Reputation: msxtr's Avatar
    Quote Originally Posted by jkg
    Thanks.
    Hi, You can use li-ion batteries perfectly, but the voltage have that are equal to your NiMh. Your charger it is not valid from li-ion batteries. You would have buy another specific charger to li-ion.
    Greetings - Saludos
    msxtr
    Warning!!! my english is very very bad, sorry.
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
