Khatod xpe optics- Mtbr.com
Results 1 to 22 of 22
    Reputation: bumphumper's Avatar
    Jan 2009
    Khatod xpe optics
    Has anyone used the 1" dia quad optics? Any info and beamshots would be great as the data sheet didn't seem to be much help to me.
    Cheers
    Reputation: tamen00's Avatar
    I am running one of the quads for a bar mounted light and it works very well. I have the narrow one and it looks a lot like 3 narrow 1 eliptical 10 mm square optics... if that makes sense. There is enough throw and spread to make a very nice bar mount... I think that it might be a little floody for a helmet mount light though.
    Reputation: zen bicycle's Avatar
    od texas has a thread somewhere on here with a beamshot of a quad optic I believe
    I want to see beam shots of the khatod 39mm 7up optic. Now thats a lot of LED crammed into a little space.
    Quote Originally Posted by bikerjay
    I was supposed to have one coming from cutters along with some other newish stuff but it has not arrived yet .
    Jan 2009
    Thanks for the description Tamen00, just ordered a few quads for new projects...
    7up would be interesting with xpg...Hmm, 2400 lumen!
    Quote Originally Posted by troutie-mtb
    Are cutter now stocking this lens, can't find it on their web site?
    Yes we have several new PCBs/Optics
    7 up Optics
    http://www.cutter.com.au/proddetail.php?prod=cut933
    PCB to suit is about two weeks off
    http://www.cutter.com.au/proddetail.php?prod=cut935
    This is a 25mm Quad XPE/XPC/XPG board to suit Khatod 25.4mm and 35mm Quad Optics
    both PCB and Optics in stock
    http://www.cutter.com.au/proddetail.php?prod=cut936
    This is the triple XPE/XPC/XPG board to suit 35mm optics
    Cheers
    WeLight
    Cutter Electronics Pty Ltd www.cutter.com.au
    Reputation: yetibetty's Avatar
    WeLight, thanks for the links.
    Do you know if the optics designed for the XP-E/C will work with the XP-G ?
    Hi YB
    The concensus from Cree is that they will. It is difficult to apply that to every optic out there as some are marginal quality but we expect for all our Optic vendors for that to apply
    Cheers
    WeLight
    I've just had a look at the 32mm PCB with triple XP.. to replace the triple XR-E PCB but will you be doing a quad version like you do with the XR-E?
    I have a few of your quad XR-E kits and it would be great to fit a quad XP-G in the same housing.
    Reputation: znomit's Avatar
    Quote Originally Posted by yetibetty
    With XP-G three is the new four
    Yes the 25mm fits the PL1125xx series
    so it is the same footprint as 25.4mm optic only it fills out to 35mm
    Cheers
    WeLight
    Quote Originally Posted by znomit
    I love your thinking on this
    ok something to consider, a vf chart I have seen puts XPG at 1Amp at 3.30vf, means 14.8v battery with a bflex and vf of 13.2, will be a nice workable combination
    Cheers
    WeLight
    Quote Originally Posted by WeLight
    I Just realised I have one that Mark sent a sample of tucked in with an order
    will try and cobble a beamshot in the next few days
    with the clear outer it would also look cool with the glow paint inside
    Confirming XPG VF
    Just tested with the XPG and they are around 3.3vf on start up and settled to 3.2 at 1Amp.
    So 12.8 to 13.2vf for a quad. Very cool
    Cheers
    WeLight
    When will you have the XPG's instock?
    Thanks for the update on the XPGs.
    Randomhead
    I don't know if that is an update. I think it might properly be called a "tease."
    I am wondering about the XP-G pricing when the MC-E was new it was outrageous. If the XP-G is priced like a higher than R2 bin xp-e it will become a clear dollar per lumen winner.
    Jan 2009
    Trying really hard not to get too excited about the xpg....
    They're going to be really expensive, not as easy to focus as an xpe, run hot etc etc BUT do I want 7 of the little beauties in an optic 1 1/2" dia? YOU BET!!!!
