Ikea Integration Sphere- Mtbr.com
Results 1 to 2 of 2
    Sep 2018
    Hi, just wanted to share my latest project: an integration sphere. Last time I was at ikea I found a glossy white box with lid called kuggis for 10 Euro.
    There is a hole in one of the sides which I used to glue the sensor and diffusor of my luxmeter in. This fits perfectly There was a little light coming to the sensor so I glued a cap of a Tetrapak to it. Now it is perfectly shielded. I drilled a 70mm hole in the lid and becaus the box is glossy, I lined it with white paper.
    Results are very promising: works for spots and flood, doesn't react to sensible on slightly different positions and delivers interesting and consistent results.
    Here are some pictures:
    Attached Thumbnails Attached Thumbnails Ikea Integration Sphere-20181127_223104_resized.jpg
    X83
    X83 is offline
    May 2018
    You should consider coating the inside with mixture of pure white paint and barium sulfate powder, which will help diffuse the reflectance for a more accurate measurement.
  1. DIY Integrated Sphere
    By colleen c in forum Lights DIY - Do It Yourself
    Last Post: 07-08-2014, 09:50 AM
  2. Shimano XT SL78 I-spec Integration Unit Pair
    By daytona in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-07-2012, 09:00 AM
  3. Avid Brake Caliper Sphere Washers?
    By Stumpjumper61 in forum General Discussion
    Last Post: 08-19-2011, 10:41 PM
  4. Ikea - at least in Schaumburg
    By CdaleTony in forum The ReCycle Bin
    Last Post: 01-07-2008, 07:01 PM
  5. Working for Ikea
    By Hudnut in forum General Discussion
    Last Post: 04-26-2006, 03:25 PM
