How to wire a system with two drivers?- Mtbr.com
Results 1 to 11 of 11
    I have two small boards which can only provide 500mA each and want to use them in series to feed two leds in series at 1000mA.
    How do I need to connect the battery -> both drivers -> both leds?
    Thanks!!
    Randomhead
    I doubt you can do what you want. If anything, you would have to put the drivers in parallel
    Carbon8er
    Reputation: El34's Avatar
    Jan 2009
    Don't know which boards you are using, but yes, you probably have to wire them in parallel.
    I have info here on how I use two 1400ma boards in parallel to get 2800ma
    http://www.el34world.com/Misc/bike/BikesLights26.htm
    Reputation: ianrab's Avatar
    I believe if you wire the drivers in parallel and the LEDs in series, then that would provide what you are looking for.
    (remember: current ≠ voltage)
    --Ian
    ŻŻ ̯ _,ŻŻ
    Quote Originally Posted by El34
    https://www.el34world.com/Misc/bike/BikesLights26.htm
    Saw your diagram but don't know if I did understand it completely. Getting rid of the switch woul this be correct? It's a conectino of two equal drivers to have their Ah added to just one only LED.
    Quote Originally Posted by ianrab
    Yes, with current I meant mA and not volts.
    Is the diagram I put correct for a one led config?
    Carbon8er
    Jan 2009
    looks good except that you only need to jumper the + terminals once.
    The battery connection below already jumpers the + terminals
    The simple way to think of it is like this.
    Hook up Board1 the normal way you would.
    Board2 gets jumpers from Board1 over to Board2 to the exact same hookup points
    If you wanted to add 3 or 4 boards, you just keep jumpering each board to the next board.
    And this would be two led's in series
    Perfectly explained mate!! Fully understood now with both your text and drawing
    Carbon8er
    Jan 2009
    excellent.
    see ya
    Don't you need to do something with the outputs from the second board? (And, if not, why???)
    Carbon8er
    Jan 2009
    yes, that is just a simple diagram illustrating the parallel concept
    The driver boards I use have 3 connection points.
    battery +
    battery -
    and LED - that is fed from the current limiting cicuitry
