Homemade Mini Lathe Aluminium Alloy with Slide CNC Linear Ball- Mtbr.com
Results 1 to 2 of 2
    Jun 2015
    Upset Homemade Mini Lathe Aluminium Alloy with Slide CNC Linear Ball
    Homemade Mini Lathe Aluminium Alloy with Slide CNC Linear Ball Bearing Motion Bearing
    Parts and Tools:
    Wood MDF 200 mm x 650 mm x 20 mm
    2pcs SCS10UU 20 mm Linear Ball Bearing Motion Bearing CNC
    2pcs 500 mm 20 mm Linear Rails
    1 Pcs 530 mm x 140 mm x 12 mm Aluminium Alloy 6061
    2 Pcs 60 mm x 140 mm x 12 mm Aluminium Alloy 6061
    2 Pcs 80 mm x 120 mm x 12 mm Aluminium Alloy 6061
    1 Pcs 80 mm x 140 mm x 12 mm Aluminium Alloy 6061
    1 Pcs 80 mm x 110 mm x 62 mm Aluminium Alloy 6061
    1 Pcs 12 mm x 140 mm x 12 mm Aluminium Alloy 6061
    Lathe Chuck 80 mm 2 pcs, Head Chuk Drill,
    More Step by Step and More Homemade Lathe DIY Mill Miling CNC Router here:
    Obi
    Obi is offline
    -_-
    Umm, dummy, what does this have to do with Lighting (DIY)?
    Also, why are you tagging your posts with a frowny face? That implies it's a bad product report.
    GO SWAP SPAM ELSEWHERE! (REPORTED)
  1. Homemade Vertical Mill Router by Aluminium Alloy Profile very easy and cheap
    By doitbymyhand in forum Lights DIY - Do It Yourself
    Last Post: 07-07-2015, 07:13 PM
  2. ​Homemade mini Lathe by Aluminium Alloy
    Last Post: 06-20-2015, 01:14 PM
  3. My XFusion Velvet much more linear feeling than XF Slide
    By mtbdcd in forum Shocks and Suspension
    Last Post: 10-01-2012, 02:20 PM
  4. Need some help with my new lathe?
    By bad mechanic in forum Frame Building
    Last Post: 02-11-2012, 04:34 PM
  5. Homemade Chainstay Protector Mini Review
    By Cobra Driver in forum Beginner's Corner
    Last Post: 08-14-2011, 09:54 PM
