Here is one for a DIY- Mtbr.com
Results 1 to 9 of 9
    For the price this is pretty impressive even for a novice to knock up and get a cheap light set-up going.
    http://www.rotorburn.com/forums/showthread.php?t=176859
    Lets RIDE!
    Reputation: Jim Z in VT's Avatar
    Clever and simple. Dude should buy a new helmet though!
    JZ
    It's not about speed, it's about lack of control.
    Yeah the helmet is a disaster isn't it
    May 2005
    Very simple, does it use a driver? What good battery / battery combination to use. Want to hear words from expert DIY'er here. What can you say about this light?
    Lets RIDE!
    Expert DIYer? I won't make any claims like that! But I think these led replacement units for track lights are self-contained....whatever driver circuit is needed is built into the unit.
    He's using 10 x AA batteries for a nominal 12v, and I expect any 12v source would work.
    I do wonder about the beamshot, and what settings were used, because it seems unusually good for a single 3w LED.
    JZ
    Quote Originally Posted by JimZinVT
    JZ
    That's something that had me puzzled that light unit I think I read was 170 lumens and if that is the case not knowing much about it the image sure portrays it with allot more lumens in my opinion.
    PCC
    PCC is offline
    The first thing I noticed was how beat up that helmet was. It's probably been due to have been replaced a season or two ago!
    If you follow the link in that thread you will see that the lamp is rated between 8 and 16V. It'll run on either AC or DC as well. It's a 25 degree beam angle and a 15 degree beam angle is available as well for cyclists.
    WRT to the beamshot, the camera was probably set to automatic exposure. Still, at 170 lumens it beats my Minewt Mini-USB by about 60 lumens.
    May 2005
    Quote Originally Posted by PCC
    Simply looking on the beamshot, i cant believe its 170 lumens, probably higher, its so bright. Any suggestion of battery combo best for it, 10 pcs so many i think. Any by the way, hope to see more beamshots of this light.
    Reputation: znomit's Avatar
    Generally the built up units use older, less efficient leds.
    Beamshots are misleading, see how bright the sky is?
    3W led beating a 20W halogen(300-400lm)?
