have dead mj808, need advice on what to replace guts with- Mtbr.com
Results 1 to 8 of 8
    Let me begin by saying I am a total novice. I have an mj808 that was my first helmet light back in 2010 originally equipped with a p7. Eventually it died and now I am left with the case that I would like to use as my first project.
    I was wondering if I can use an mt -g2 such as this
    Cree MT-G2 P0 5000K 6V LED on Noctigon MT-G20 Copper MCPCB
    if anyone has a better suggestion I am all ears.
    Will also need a driver, suggestions are welcome.
    I already have a gloworm x2, Gemini olympia, a couple Gemini titans, and Just ordered the securitying version of the duo clone and uniquefire that has been reviewed extensively here so I don't have any specific requirements but figured I would aim for maximum output for a single emitter
    Again, total noob so please let me know what my best options are and sorry if I come off sounding foolish
    Thanks in advance
    Was looking at this driver if the MT-G2 will work for me
    QLITE MT-G2 Zener Mod
    You can use driver: 4-Mode 0.8~1.5A LED Driver Circuit Board for XM-L Bicycle Headlamp / Flashlight - Black (3.0~8V) - Free Shipping - DealExtreme and any XM-L2 led. MT-G2 might go, but be prepared you'll get much more spill and less throw. Never tried MT-G2 with that driver, though.
    Thanks for the response. I think I will go with the driver you posted and an xm-l2 as the driver is already set up with the switch where it needs to be and everything. It is probably a better bet that I keep it simple this time around as I'm notorious for abandoning projects when I hit a roadblock. MT-G2 will be for another day
    I'm glad I could help. If you like to raise the current add some sense resistor over the existing R100. Read also is it a mistake in the description? ? DealExtreme Forum
    Thanks, am checking the link now!
    If you are satisfied you can give me some +rep points to improve my image
    Done, just learning about the rep system. Thanks again. The securitying versions of the KD 2 and uniquefire that I ordered should be here tomorrow from amazon. Look forward to ripping into them and doing the resistor mod as well
  1. GUTs
    By cabra cadabra in forum New Mexico
    Last Post: 06-14-2012, 01:22 PM
  2. Replace an old friend, moslty. I need advice
    By trythis in forum Bike and Frame discussion
    Last Post: 09-24-2011, 06:20 AM
  3. Advice: rebuild RP2 -or- replace with Monarch RT3
    By r1de in forum Shocks and Suspension
    Last Post: 08-16-2011, 02:02 PM
  4. Magicshine MJ808
    By Yukon-RSX in forum Lights and Night Riding
    Last Post: 07-18-2011, 07:20 AM
  5. Replies: 6
    Last Post: 02-27-2011, 06:52 PM
