Ghetto inner tube mount- Mtbr.com
Results 1 to 9 of 9
    Here is a home made torch mount I have been using for a few years. Thought I would share it on here.
    Take one old inner tube and cut to the size of the torch.
    Cut a section out of the middle.
    Pull the tube through the torch under the Bars then feed the torch into the tube again. Using the section you cut out to place between torch and bars for padding.
    It works on the bars or a vented helmet. You can also use the section you cut out to place under the torch to prevent rub.
    Enjoy
    That's a great idea. Cheap and simple. Thanks for sharing.
    Can you adjust the torch on the bars left/right so it points forwards?
    mtb enthusiast
    Reputation: torreyaz's Avatar
    K.I.S.S. Awesome job, cheap and low weight.
    Quote Originally Posted by JezV View Post
    Yeah my bars are angled thats why it looks like its pointing left. I just put it on quick for the photo.
    Cheers
    Genius!
    Does it move when riding? I have a problem with my current flashlight mount on fast or bumpy decents my light starts point more and more down and I have to readjust it when I am riding. If this doesn't do that it would be worth my while to try this out.
    Quote Originally Posted by brent878 View Post
    To be honest it did at the start. I then tried to use the stem to steady it. Its a quick fix type thing. I ended up using mainly the light on the lid as its solid. If you get a really tight tube it doesnt move too much if the torch is balanced on both sides. A wee bit of weight on the back cuts down on it moving.
    I now use a Magicshine.
    Nov 2008
    Great idea, still works, used it to mount a Bluetooth speaker
    Nov 2014
    Nice work, I needed a helmet lite
  1. Ghetto GoPro mount on an RFX
    By flipnidaho in forum Turner
    Last Post: 03-04-2011, 10:54 PM
  2. Recommended Tube for Ghetto Tubeless
    By turboox in forum Wheels and Tires
    Last Post: 09-03-2010, 02:07 PM
  3. ghetto tubeless width of tube
    By andresmuro in forum Wheels and Tires
    Last Post: 12-24-2009, 08:16 PM
  4. Ghetto Tubeless-24 inch tube OK?
    By Uncle Six Pack in forum Wheels and Tires
    Last Post: 06-15-2009, 07:10 PM
  5. tube for ghetto tubeless ???
    By eric_syd in forum Wheels and Tires
    Last Post: 08-30-2008, 06:44 PM
