Gemini Olympia disassembly / repair- Mtbr.com
    Candlestick Maker
    Reputation: baker's Avatar
    Anyone out there disassembled a Gemini Olympia lighthead? I crashed hard and hosed up the power button (sorta pushed into the body of the light). It still functions, but is really hard to cycle through modes and there is no longer any tactile feedback. I'd like to fix if possible, but don't want to hose up the light by incorrectly disassembling.
    baker
    NightRider
    Reputation: gipsyman's Avatar
    Nov 2014
    Disassembling Gemini Olympia
    Quote Originally Posted by baker View Post
    I disassembled 2 of mine before. First you screw off the bezel, then lift out the triple lens. Depending on what build you have there may be a hold down screw on the face of the pill to remove. If no screws, then you can pull out the pill with the triple led board. You should now be able to get to the driver board side of the pill. I would apply some silicone grease to the on/off button sides to increase water resistance. I also applied a little heat sink compound to the pill outer surface to increase thermal conduction when I took mine apart. While you have the light disassembled you might want to polish smooth the triple lens to increase light collimation. That polishing made my light beam a little tighter.
    Candlestick Maker
    Thanks gipsyman, much appreciated.
    baker
    Candlestick Maker
    gipsyman-
    I have the lens and triple led board removed, but don't understand how to get behind the part where the led board rests. Is there anything in particular that I need to do to get in the back part of the light (where the driver and switch reside)?
    thanks
    baker
  1. Gemini Olympia 2100 Xm-L2
    By the mayor in forum Lights and Night Riding
    Last Post: 09-26-2014, 01:57 AM
  2. Gemini Olympia? End of Charge Behavior?
    By dcelento in forum Lights and Night Riding
    Last Post: 09-27-2013, 10:40 AM
  3. Flash frequency on Gemini Olympia/Duo?
    By seeker in forum Lights and Night Riding
    Last Post: 12-05-2012, 05:16 AM
  4. Gemini Lights OLYMPIA LED (2012)
    By Gemini Lights in forum Lights and Night Riding
    Last Post: 09-10-2012, 04:24 PM
  5. gloworm or gemini olympia
    By Leethal in forum Lights and Night Riding
    Last Post: 01-27-2012, 04:31 PM
