Flickering on maxFlex- Mtbr.com
    Reputation: piesoup's Avatar
    Hi
    I have a MC-E in series wired up to a maxflex with a 3S Li-Ion battery. In the lowest mode the LEDs flicker. However level 2 to 5 the light is steady.
    I have let the light run for a while to lower the voltage and also connected the same battery to a 4 x XR-E and it still flickers on the lowest setting.
    Anyone know a reason for this?
    Reputation: bumphumper's Avatar
    Jan 2009
    Just a guess....Could the maxflex be flickering in and out of regulation because the Vf of the led and battery voltage are almost the same? At the lowest setting the total Vf could be about 11 volts.
    Reputation: heatstroke's Avatar
    Jul 2003
    MCE = 4x (3.1low ? ~ 3.3High ?) V = (12.4 ~ 13.2)V
    3sLipo = 3x4.2 = 12.6V
    I think bhumper is right
    Thanks chaps, thats excatly what i thougth! Will use Duo mode instead. Also going to use the Bflex and use 4 Li-ions in my future lights. I only get 1:20hr runtime with 11.1v and a maxflex.
    Ta very much
