finally pulling the trigger few questions- Mtbr.com
Results 1 to 5 of 5
    Dec 2008
    after lurking for 3 or 4 monthes I am finally going to order the parts to build a light. I understand for the most part how stuff works and wiring I just have a few last questions.
    I have been riding with a 100 lumen light I want a bar mounted light that is 3-500 lumens with a high 4-600 and a low 2-300. I want to know if this can be accomplished with 2 emitters or should I opt for 3?
    also what type of driver should I use? to get a high low and off?
    by helping me decide which driver and emiters to use I will pull the trigger on purchasing it all. if you ahve a battery charger solution as well give me that too.
    One Gear
    Reputation: .40AET's Avatar
    Which LED's are you designing around? There are a lot of possibilities. Some, are really easy and you can end up with close to 700 lumens.
    Lets RIDE!
    Reputation: Jim Z in VT's Avatar
    The cheap-er and easy route would be two XR-E R2s in an Achesalot style case, a buckpuck driver, and a battery of ~9v or better. That gets you into the high 400s. The dimmable buckpucks can be controlled by a variable resistor (a.k.a. "pot") or a hi/lo/off (or hi/med/low) toggle switch.
    Or up it to 3 leds and a battery of 12v or more, and you've got 700+ lumens.
    Batteryspace.com usually has some good deals on NiMH water bottle batteries with smart chargers, including the cable and connectors.
    And a CatEye handlebar mount.
    JZ
    There are many cooler and more state-of-the-art ways to do this of course, just depends on what your budget and priorities are
    It's not about speed, it's about lack of control.
    Dec 2008
    I have limited moderae technical skills and I was thinking 2 LED light would be best but if three isnt that much harder/power hungry i could do that too
    I was thinking of using aluminum piping as housing.
    I want easy of building/use
    I want the lumens stated and I want to go with a lithium battery pack/something small.
    burn time should be 2-4 hours depending on price
    i just got a job at the LBS so I can now Employee purchase lights which is going to mkae any light i build close to or more expensive but I would like to build it out of fun/enjoyment.
    I went triple XPE because I liked the small size. 750mA Buckpuck and 14.8 Li-ion battery pack. It works great and is very bright. I haven't measured output directly, but the CREE calculator puts it at around 530lm.
