Easy2LED M36?- Mtbr.com
Thread: Easy2LED M36?
    Hack Racer
    Reputation: Cheers!'s Avatar
    Easy2LED M36?
    Anyone do a nice Easy2LED M36 build lately?
    Hack Racer
    Let's see if I can kick start this a bit...
    Thoughts on what driver I should use to drive this?
    Noctigon XP32 MCPCB & CREE XP-L V6 3D LEDs [SKU L055] - $23.98 : Led Flashlight-International Outdoor Store
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Quote Originally Posted by Cheers! View Post
    This is what I'd suggest given the space available in the M36 pill: b3Flex Product Description
    TaskLED drivers are what I've used in pretty much all my builds and highly recommend them if you want reliability and flexibility. They are a bit expensive, but I haven't found anything else like them for the DIY builder.
    I finished a M36 rebuild recently and I think it is quite nice. I originally had a 2nd generation b-flex and a cree mk-r. It was good.
    The new build spec.
    A h6 flex driver - it fits if you put the threaded inside in backwards. Also have to file it a tiny bit to get the wires in.
    New Easy2led M36 build with Cree XHP70 and H6flex- Mtbr.com
    Cree XHP-70 - its a 6 volt part and 90cri at 4000K. - The quality of light is among the best I have ever seen.
    I also found an anodized black aluminum momentary push button switch on ebay.
    Also stepped up the aluminum front and back cap upgrade.
    I use a go pro to tripod screw (1/4" 20tpi) adapter for mounting since the hole is already drilled and tapped and various gopro mounts since I have them and they work well enough.
    I think there are more optics available now. I may still try a few more.
    This thing coped with the heat of 30-40 watts much better than expected but if i is really hot out or I am not moving it does kick down.
    Over all I am quite pleased.
    If you just want lots of throw a new xpg3 triple might be best.
  1. Easy2led.com DIY light bodies.
    By zemike in forum Lights DIY - Do It Yourself
    Last Post: 12-07-2012, 11:44 AM
  2. Anyone building with the Easy2LED M36 housing?
    By adrenalnjunky in forum Lights DIY - Do It Yourself
    Last Post: 11-13-2012, 04:02 PM
  3. Anyone run an MCE at 100% in easy2led body?
    By gticlay in forum Lights DIY - Do It Yourself
    Last Post: 11-07-2012, 01:02 PM
  4. Another Easy2LED XM-L build
    By mattthemuppet in forum Lights DIY - Do It Yourself
    Last Post: 12-28-2011, 12:46 AM
  5. Easy2LED XM-L build
    By Ofroad'bent in forum Lights DIY - Do It Yourself
    Last Post: 12-23-2011, 02:38 PM
