Dual XPG DIY question- Mtbr.com
Results 1 to 7 of 7
    Ordering parts to build up a dual XPG w/ regina optics. I've already order the R5 LEDs, 1000ma buckplus driver (no dimming controls) and 2 Regina's from Digikey.
    My question is would the driver work more efficient with 3 18650 batteries in series or 4? I'm about to place my order through battery space for the holders, cables and switch.
    thanks
    Reputation: yetibetty's Avatar
    3 cells would be perfect but you could get away with 2 if you don't mind your light going dim towards the end of battery discharge.
    I use 3 cells on my 2x XPG (with bFlex) no going dim no problem. You won't want 4.
    eeh I don't want any dimming, I'll order the 3 cell. Thanks
    Stupid question. Why not 4?
    May 2005
    Quote Originally Posted by Dream Plus
    4 cells would work fine, longer runtime at very slightly less efficiency. The runtime would likely be longer than most people would need. Therefore most would settle for 3 cells.
    The LEDs will require around 3.2v each so that's around 6.4v for the pair, then add a volt or two for the driver and you get 8.4v. That 8.4v is the min requred to stay on full power.
    3 X 18650 cells will go from 12.60v when full down to 9v when empty so is near enough perfect.
    4 x 18650 cells would start out at over 16v and be empty at around 12v.
    parts are starting to arrive!! yay
