dual MC-E- Mtbr.com
Results 1 to 5 of 5
Thread: dual MC-E
    Jan 2009
    dual MC-E
    so i went ahead and built up a dual MC-E. here is how is turned out.
    and of course here are some beamshots
    first is control
    here is low
    and here it is on high
    what do you guys think?
    Dec 2008
    Nice1,i just made a couple of P7 lights,looks like similar output to mine.
    What reflectors did you use?
    Tommo.
    Jan 2009
    thanks. for the optics i went with an LM1 D and a LM1 RS
    One Gear
    Reputation: .40AET's Avatar
    Nice, neat looking light. Could you please post the build parts? (driver, batt, etc.) I'd like to pick up some of the Hammond cases for my next builds. That case looks like a good size. Do you have the part number for the case?
    Jan 2009
    this is the case i used and i cut it in half 1455J1202BK. they are M bin series stars wired in parallel off a 1000 buck puck so each die gets 500mah. the connectors are switchcraft EN3 series. the switch is just a cheap dealextreme clicky switch. and for a battery im using a 14.8v 4400mah Li ion.
