DIY Diffuser?- Mtbr.com
Results 1 to 3 of 3
Thread: DIY Diffuser?
    Feb 2006
    New question here. DIY Diffuser?
    I've got a Niterider Pro 1500 I've been using on my handlebars with a Magicshine MJ900 on my helmet. I'm pretty happy with the MJ900 on my helmet to handle the spot light duties, but I'd like to widen out the beam on the Niterider a bit to give me more of a flood light. Does anyone have any suggestions about how I might go about that?
    X83
    X83 is offline
    May 2018
    I'd take the light apart and measure the lens then find a suitable replacement stripe type lens to widen the beam pattern.
    Here a good source for lenses after you find the correct size. https://www.aliexpress.com/store/all...190226e8iNwg92
    https://www.action-led-lights.com/co...ics-reflectors
    Action LED Lights
    Reputation: Action LED Lights's Avatar
    Quote Originally Posted by X83 View Post
    Our wide angle lens is 39mm in diameter but can always be cut down to fit your light since is looks like it's smaller. You can either replace your current cover lens or use some small spots or glue and attach it on the inside or outside. For lights with a lens greater than 39mm you can still attach it to your current lens and it will spread all the light that hits it.
    Jim Harger
    Action LED Lights
  1. Betty R with Diffuser (Bar Mount)
    By stu06 in forum Lights and Night Riding
    Last Post: 12-19-2014, 08:49 PM
  2. Flip down diffuser
    By DIYtailight in forum Lights DIY - Do It Yourself
    Last Post: 11-13-2011, 07:56 PM
  3. Diy
    By fused in forum Shocks and Suspension
    Last Post: 01-07-2011, 09:37 AM
  4. What DIY voltage regulator for DIY lights
    By dmalovic in forum Lights DIY - Do It Yourself
    Last Post: 11-29-2005, 11:17 AM
  5. Replies: 18
    Last Post: 10-14-2005, 11:50 AM
