DIY Diffuser?
Printable View
  • 11-08-2018
    mwalker411
    DIY Diffuser?
    I've got a Niterider Pro 1500 I've been using on my handlebars with a Magicshine MJ900 on my helmet. I'm pretty happy with the MJ900 on my helmet to handle the spot light duties, but I'd like to widen out the beam on the Niterider a bit to give me more of a flood light. Does anyone have any suggestions about how I might go about that?
  • 11-11-2018
    X83
    I'd take the light apart and measure the lens then find a suitable replacement stripe type lens to widen the beam pattern.
    Here a good source for lenses after you find the correct size. https://www.aliexpress.com/store/all...190226e8iNwg92
    https://www.action-led-lights.com/co...ics-reflectors
  • 11-20-2018
    Action LED Lights
    Our wide angle lens is 39mm in diameter but can always be cut down to fit your light since is looks like it's smaller. You can either replace your current cover lens or use some small spots or glue and attach it on the inside or outside. For lights with a lens greater than 39mm you can still attach it to your current lens and it will spread all the light that hits it.
