Dinotte AA Battery Holder Options?- Mtbr.com
    I have a Dinotte that uses the 4AA snap holder.
    Anyone have an option or an idea what I can use to replace this?
    I love the light but the connection is spotty at best and I've replaced the holder several times.
    Rob
    You can try these. You don't necessarily have to get these at radio shack, but they're the most convenient source:
    http://www.radioshack.com/product/in...LAID=107591570
    http://www.radioshack.com/product/in...ductId=2062244
    http://www.radioshack.com/product/in...ductId=2062239
    That was part of it
    Thanks, I actually did see those and the first in the case looks best. I was looking also for a waterproof SOLID connector
    Actually all you have to do is run out to Radio Shack and buy a set of new connectors and splice them in. There are many types to chose from so buy what you want. Those 9volt connectors are a pain once they get used a couple times. Just keep in mind you can improve the connections by taking some needle-nose pliers and tightening the snaps.
