DC waterproof connectors?- Mtbr.com
Results 1 to 3 of 3
    New question here. DC waterproof connectors?
    Hi Gents, on many of the light builds, I see guys using waterproof connectors. Where are they sourced from. Any leads or supplier info will be appreciated.
    thanks
    Thys
    aka Chris
    Where are you?
    In the UK, Farnell and RS sell the AMP SuperSeal connectors which are what I use. You need to buy the hoods, pins, plugs etc as individual items. Also look for them on eBay as complete items which can make life easier.
    Couple of good threads:
    http://forums.mtbr.com/showthread.php?t=373130
    http://forums.mtbr.com/showthread.php?t=516449
    The Novice's LED Light Building Blog
    Quote Originally Posted by thysmeades
    thanks
    Thys
    Thys
    You dont really need waterproof connectors unless like you have done it is a chassis mount , and then it is needed to keep the water out of the housing .
    Have a look at the Binder 720 series and 620 series they look quite neat.
