correct cable AWG- Mtbr.com
Results 1 to 8 of 8
    Jun 2010
    Caution;  Merge;  Workers Ahead! correct cable AWG
    hi there, looking to mod my hope 2 led with fresh Lflex and 2 XML's like seen here from the dude that knows it all too well.. trout..
    now I'm confused with all the gauge sizes.
    the 2 xml will draw about 4.2+4.2= 8.4V at tops of 2.5A (wont drive it more than 2A but maybe give it a go..) correct?
    which gauge will i need to wire up leds to Lflex?
    and what gauge between the battery- headlight unit? (would like aprox 60-80 cm of cable - battery is in the bag and light is a helmet light (because it's so lite!!)
    yours truly GOZAL
    The hope lead will do fine for the power supply
    and you wont get huge cables in the Lflex solder holes so just use what will fit in the holes
    its a dead easy upgrade and stunningly bright even at 1.5 amps drive
    over here in the uk they are using the 2 amp setting and keeping nice and cool .
    its a nice little housing .
    Jun 2010
    thanks for the rep.
    but, what gauge to buy? dont know..
    May 2005
    22AWG will work.
    Jun 2010
    thanks for the tip Vancbiker , can someone give me a formula or a thumb rule on this case?
    May 2005
    Quote Originally Posted by gozal View Post
    Google chassis wiring ampacity
    You will get results that vary widely. I use a chart published by HP for use in equipment. It is fairly conservative. Lots of charts will say for example that 22AWG will carry 7A. Look at the fine print and you see that is for a single conductor in free air. Not the case in a light! With a chart like that I would de-rate by ~50%.
    Reputation: HEY HEY ITS HENDO's Avatar
    ...Scun.thorpe, UK
    Nov 2006
    I see this table referenced often. Can somebody explain the difference between chassis wiring and power transmission. It seems like everyone quotes the chassis wiring specs. Why wouldn't our lights require the power transmission spec?
    Thanks,
    Andy
  1. Help sourcing spokes
    By jparman in forum Wheels and Tires
    Last Post: 06-30-2011, 05:23 AM
  2. Help Sourcing a Tire in the GTA.
    By bigwheelboy_490 in forum Eastern Canada
    Last Post: 06-27-2010, 04:26 PM
  3. Pem nut sourcing?
    By campredcloudbikes in forum Frame Building
    Last Post: 10-21-2009, 06:38 AM
  4. Need help sourcing V10 shock!
    By Yeti Maniac in forum Santa Cruz
    Last Post: 05-29-2009, 04:58 PM
  5. Stem Sourcing...
    By 2xPneu in forum 29er Bikes
    Last Post: 10-01-2007, 09:43 PM
