Circuit Sketch?- Mtbr.com
Thread: Circuit Sketch?
    Reputation: arphaxhad's Avatar
    Circuit Sketch?
    Hello,
    I am wanting to run 3 lights (magicshine 808's) off of 2 of the standard 8.4v 4400mAh batteries.
    I can fabricate the connector but need a little help in how to wire it. Anyone willing to do a quick sketch of such a 2-battery/3-light connector for me?
    Did I mention that there are +reps involved?
    TIA
    Don't know where do you want to run this setup, but it is pretty straitforward. You need to connect all inputs in parallel and all outputs in parallel. That's it. Of course + and - should be separated (obvious, but just in case )
    For a test (at least) you can play with 2.1x5.5mm DC CCTV connectors (search at eBay or elsewhere).
    Thanks Ledoman
    I knew I wanted to run the batteries in parallel to keep the voltage the same, but wasn't sure if the lights did a weird series thing.
    p.s. thanks for the connector info...
    No problem. You are welcome. There is one thing I need to mention. You might experience some flickering when connecting more than one light in parallel. If this happens I would try to add some hi grade capacitor to the wireing you are going to do. So you solder + and - of the capacitor to the apropriate wires comming out of battery packs. In theory it would be the best to have capacitors as close to the light heads as possible, but it is unpractical.
  1. RF Turbines circuit '98
    By Crash_FLMB in forum Singlespeed
    Last Post: 09-10-2015, 10:15 AM
  2. Homemade chainguide sketch
    By skulboy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-24-2015, 03:11 PM
  3. 2008 Opus Sketch
    By T-Wort in forum Bike and Frame discussion
    Last Post: 09-23-2013, 06:38 PM
  4. Google Sketch up Design for my next light
    By bikerjay in forum Lights DIY - Do It Yourself
    Last Post: 03-28-2012, 02:04 PM
  5. Circuit Training
    By Mr Pink57 in forum XC Racing and Training
    Last Post: 01-01-2012, 09:26 PM
