Cheap lights?- Mtbr.com
Results 1 to 10 of 10
Thread: Cheap lights?
    Cheap lights?
    What are some quality dual beam lights for $150 or less?
    Are there any in that price range?
    J-Mizzle
    For about $85 more, you can get HID
    I think you can get LUME's now for around $235. I don't have HID, and don't feel like I need them, but with prices dropping, it might be a good investment. My buddy has these and loves them. Bright, reliable, simple...
    FWIW, I've gone the cheap light route, and it seems I was never satisfied. Luckily, a friend helped me convert a cheap lightset to a pretty nice 13.2v, 20w set for little money (his experience was invaluable!), but assuming that was not available to me again, I would not go that route again.
    Also, a lot of folks like Jet's for good value.
    Note: I did not respond to your specific need for dual beam, so I guess I should ask why Dual? I think it is not needed, and you'd be better off with a single helmet, and eventually a single bar mount, rather dual bar. For the single bar, as a second light you can go cheaper, I like the NR TRII, which can be got for around $80 when on sale. Simple, reliable, and a good supliment to helmet lite. Real life saver if you have helmet problems. (If you have problems with your dual, or burn up the battery in the woods, you are S.O.L.
    Hope that helps.
    Cygo
    Quote Originally Posted by J-mizzle
    J-Mizzle
    NiMH for $80, and the 3 I know who have them are all happy.
    consider cygolite
    i've had good success with the fairly inexpensive cygolite explorer and rover lights. they're inexpensive and work great, helmet mounts are inexpensive.
    read the reviews on mtbr
    john
    J-Mizzle
    Do It Yourself
    Reputation: Homebrew's Avatar
    J-Mizzle
    Why the dual? From my experience, a good high powered helmet mount (e.g. 13.2V 20W) should be a primary light with a cheap handlebar mount as backup. You can find dual lights in that price range but quality isn't going to be there.
    Must be an NC thing...
    Quote Originally Posted by Homebrew
    Quote Originally Posted by Bmateo
    Two seperate lights is the way to go IMO, unless there is a reason...
    ballbuster
    Reputation: pimpbot's Avatar
    Second that,
    Quote Originally Posted by bmateo
    A helmet light and bar light combo is the way to go.
    I got a 12/20W G-Whiz Ultra Death Ray dual beam on the bars with a 10W NR Headtrip, and the combo works great for everything but high speed downhill, which I should not do at night anyway.
    I got the Death Ray for $30 used cause the boat anchor SLA battery was shot. I just built up a NiMH battery for another $30. Works great.
    In addition to that, I have one of those 3 LED camping lights that you strap on your head. I strap this under my Headtrip so I can leave it off for slow climbs. It makes a nice glow around your bars so you can see your comptuers and gear indicators.
    Thanks fellas
    I can understand the reasoning behind having one on helmet as primary, and a cheaper as backup.
    Will go that route
    J-Mizzle
    Reputation: kingfurby's Avatar
    For your single beam needs I recommend the Niterider Trailrat. It's an excellent, affordable 10 watt spot-beam system. The battery lasts around 2 hours and isn't too heavy. You can either strap it to your frame, and still use both water bottles, or slip it in your pocket if you mount it on your helmet. You could almost get two for not much more than $150, but to mount it on your helmet you need to buy a few accessories and if you buy a flood bulb the price could really start to climb. But it is at least an excellent handlebar mounted light anyway. And it is compatible with the Niterider taillight if you ever hit the road. I think the Trailrat and Roadrat are the best bargains that Niterider has to offer. Think about HID for the future though, because it is just head and shoulders above halogen lights.
    Nervous Descender
    Reputation: Adirondack Blues's Avatar
    Marwi NightPro Elite 12w helmet light teamed with a Cygolight Night Explorer 10/15/25w bar gives you excellent lighting, IMO. $180 for both.
    Check out some of our local hills: CDRC (Capital District Road Climbs)
  1. Should I buy these lights?
    By DirtSS in forum Lights DIY - Do It Yourself
    Last Post: 05-05-2004, 09:23 AM
  2. cheap hutchinson tires at greenfishsports.com
    By jason74 in forum Where are the Best Deals?
    Last Post: 04-20-2004, 08:32 PM
  3. cheap entry level repair stand???
    By richz34 in forum General Discussion
    Last Post: 03-14-2004, 10:31 PM
  4. cheap cheap HT frame??
    By rpet in forum Where are the Best Deals?
    Last Post: 03-06-2004, 04:33 AM
  5. Southern Lights 24 hour race
    By sportsman in forum Lights DIY - Do It Yourself
    Last Post: 03-02-2004, 07:35 PM
