Cateye EL530 drive current?- Mtbr.com
Results 1 to 5 of 5
    Dec 2008
    Anyone know the drive current of one of these?
    Want to put a P4 ZLed in it to give it a bit more uummph!
    Its only my backup light but its always nice to have all lights as bright as they can go!
    Cheers
    Tommo.
    Jan 2009
    What is in there currently? If it is a luxeon then a P4 wil be an upgrade no matter what current.
    Dec 2008
    Obviously,just wondered what i needed to do to get it up to the 1000mA if it needed it.
    Cheers.
    I guess there is some cheap 1 Watt led inside and a resistor to limit the current. Driving a led in that plastic housing on 1A will fry the led. Plastic is a good insulator, there is a reason that all the better lights are made from metal.
    You could swap the led for an U-bin P4, it will increase the light ouput significantly. But don't change the current too much.
    Reputation: znomit's Avatar
    Details here.
    http://www.candlepowerforums.com/vb/...d.php?t=167551
    I wouldn't run it at 1A as there is no decent path out for the heat.
