Can anyone identify this component?- Mtbr.com
Results 1 to 3 of 3
    Dec 2008
    I guess its a cap,polarity concious but i can't work out the values or find it with Google.
    I must have reversed the polarity on my Kadom board and fried it,if i can get hold of the component i might be able to save the driver.
    Cheers guys.
    Tommo.
    I am by no means an EE wizz but my humble suggestion is to look up the driver in a search on candlepowerforums.com and with any luck you will find a schematic which will specify the value. In general the DX/KAI boards follow the published circuit lay out for the integrated circuit they are based on. Another approach, since it is a surface mount capacitor is to measure the thing with calipers and, one the same size will be at least close in value. It would also be my best guess that a higher than stock value would be ok but a lower than stock value would not.
    Jan 2009
    I'm not 100% sure but I think it is a 100uF tantalum capacitor
