Buckpuck High/Low- Mtbr.com
Results 1 to 8 of 8
    Reputation: robtarr's Avatar
    Buckpuck High/Low
    Has anybody hooked up a high low switch to a Buckpuck-D-E-1000 driver? What did you do?
    Reputation: zen bicycle's Avatar
    Run a resistor between one leg of your switch and the cntrl pin. Sorry I can't remember the value. I always used a slide potentiometer for variable dimming
    The schematics show a 5k potentiometer, but I wanted to have a switch. So I tried to run a 2.2k resistor and a 3.9k resistor in series, with a switch to short out the 2.2k, but it didn't seem to have any effect on the light output.
    Reputation: yetibetty's Avatar
    You can do it with a resistor but it is very hard to find or decide on the value.
    I hope this pic helps but I used a micro pot (trimmer ?) and when I got it how I liked it I put a blob of glue on it and put it inside the housing. Still working 3 years on.
    aka RossC
    Reputation: ocean breathes salty's Avatar
    Thanks for the responses. Those posts confirmed what I found last night, so one last trip (hopefully) to RadioShack tonight should finish up this light.
    JDM
    JDM is offline
    Reputation: JDM's Avatar
    I bought the adjustable buckpuck, but haven't bothered with a switch yet. It is fixed on high for now.
    High power is good for everything except making friends.
    Reputation: znomit's Avatar
    Quote Originally Posted by JDM
    And conserving batteries.
    And stopping your light from overheating.
