battery help- Mtbr.com
Results 1 to 2 of 2
Thread: battery help
    battery help
    I'm slowly piecing a lighting system together as I have time find and make cheap parts. Next on the list is the battery.
    I took apart an old laptop battery and want to use the cells to make a battery pack for my light. Inside there are four 18650 3.2v 2ah cells wired in series to a pcb. I'll be leaving them in series for 14.4 but I won't be using the pcb as its the wrong shape and I have no idea what the pin outs are on it. I was thinking of buying a charge management boards so that I can reuse the ac adapter that came with the laptop.
    http://www.all-battery.com/protectio...s-cm-01-4.aspx
    Are there any disadvantages to using a charge management board as opposed to a normal pcb and a smart charger?
    It looks like it is more than your typical protection circuit. I think you are correct that it is a charge controller too. It's too bad that they don't have a link to some specifications.
