Battery box with USB connector- Mtbr.com
Results 1 to 5 of 5
    I thought this looked interesting:
    It is a 4xAA battery box with a USB connector. It claims to put out 5V but 4 AAs add up to 6V, so not sure about what is inside the little bit near the USB connector.
    So three possibilities, as I see it
    1. Strip out any intervening electronics and pop in the driver of choice and you have a nice little battery box with the driver well protected.
    2. There are some DC-DC converter electronics in there that could be subverted for our evil LED purposes.
    3. Strip out everything but still use the USB connector to run a USB cable to your light head (least interesting of the options).
    If Jaycar in Aus have these boxes then they are bound to be available elsewhere.
    EDIT: DX have something a little similar, but definitely no DC-DC converter:
    Off the back...
    Reputation: pinkrobe's Avatar
    I think USB is rated for fairly low current - like 300mA max or something. I can't remember where I saw the specification...
    According to wikipedia the maximum current (for a USB 2.0 port). is 0.5A.
    Off the back...
    Okay, that's not so bad then. What are you planning to illuminate?
    Quote Originally Posted by pinkrobe
    It gets better -- there are four smaller cables in a USB cable, so you could double up (should, as the cables are fairly thin) using two for +ve and two for -ve. This should allow for higher currents.
    My use for them would be power packs for commuter lights, i.e. a single Q5/R2 emitter.
