battery alternative- Mtbr.com
Results 1 to 9 of 9
    Jan 2009
    battery alternative
    i was thinking about using a laptop battery or a cordless drill battery. i need a 14.8v 4400mah battery. how do i go about using one of these?
    Jan 2009
    i found some 7.4v 4000mah li ion packs for cheap. if i wire them in series with the connector below would that give me 14.8v 4000mah? could i charge it as a 14.8v or would i have to charge each individually?
    Reputation: yetibetty's Avatar
    You will have to charge individually with 7.4v charger.
    Lets RIDE!
    Reputation: Jim Z in VT's Avatar
    Quote Originally Posted by darkendlight88
    i was thinking about using a cordless drill battery.
    There is a battery connector available made specifically for Makita cordless tool batteries. My brain just can't seem to remember who sells them....especially after my 2nd "Dark & Stormy"
    I'm pretty sure I saw it mentioned in a old thread by Troutie, as well as others here.
    JZ
    It's not about speed, it's about lack of control.
    Dark and Stormy........ You in Bermuda??? Only place I have ever seen those, and they will mess you up.
    Lets RIDE!
    Bermuda? I wish! I'm in Vermont, it's 11F tonight, and a little antifreeze is in order. Bermuda black rum and ginger beer over ice.....I like ~1:1 ratio
    JZ
    Never had one of those... never heard of a Dark and Stormy, period.
    But they sound great! I dig ginger beer... thanks for elaborating.
    If You add balancing tabs and have charger-balancer You can charge such serial pack at once - as 4 cell pack
