Bar Mount + Remote switches- Mtbr.com
Results 1 to 12 of 12
    Reputation: Goldigger's Avatar
    Sorry guys no new lights to show you..
    Machined this Ali mount up using mostly the rotary table..
    Made two little ferrels for the bolts, so they can be tightened by hand... no need to use allen keys..
    Also made two remote switches..
    This ones made from delrin, uses a O-ring to secure to the bars..
    This ones made from Ali and anodised..
    Slots in each end so that a velcro strap can be threaded through...and then secured to the bars...
    May 2005
    Beautiful work there!
    Reputation: deesta's Avatar
    Very nice work mate
    Thanks guys...
    Rep Power Infinity +2
    Reputation: brad72's Avatar
    They both look fantastic Jay
    Thanks brad...
    It was a bit time consuming making the mount and getting the shamfer to follow the contours..
    You can work it out with a cad drawing and working out the angles, then translating that to how many degrees mins and seconds etc..
    I found cutting the part of a circle on the bottom of the switch, to be a PITA on the rotary table.
    So put it in the vice found the centre and used a boring head..
    very tidy! My next bar mount is going to bolt directly to my brake lever band, so I have as little reach as possible from my grips. That or a patch of velcro
    Great job GD!
    May 2012
    Fantastic job (oh, and they seem to of found their way on too my bike!!!!)
    Thanks...
    Glad you like it
    Aug 2010
    Man, amazing work - well done!
    Thanks wquiles..
    These are the little items i could really use some CNC for...
    Here's a couple of pics of it on my bars....the light is one of my tripple XT-E's with lflex as seen in my thread here https://forums.mtbr.com/lights-diy-d...-l-759784.html
