Amoeba tail light- Mtbr.com
Results 1 to 6 of 6
    Light freak
    Reputation: scar's Avatar
    Jun 2005
    Amoeba tail light
    Some pics of a recent Amoeba tail light build -
    Housing is 2 1/8"L x 1 1/2"W x 3/4"T
    Weighs about 60 grams
    Runs off of a rechargeable 2 cell Li-Ion pack
    TaskLed LFlex driver
    Cree XP-E2 Red LED's
    Vancbiker GoPrp adapter
    https://youtu.be/i0OpojDjME4
    May 2005
    That'll get some serious driver attention!
    I think you can program some interesting flash patterns with the Lflex.
    Does it generate enough heat that the finned GoPro mount helps?
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
    nice! Good side visibility too. I programmed one of those cheap ATtiny13 drivers with a Dinotte-style on-and-double flash (on-flash-on-flash-on-on-on-on-on-flash-on-flash) a while back and it's very visible, even in bright Texan sunlight.
    With an external battery pack, scar's light should run for a long long time using an on-and-flashing pattern.
    Light freak
    Jun 2005
    One more pic with seat rail mount
    Sep 2017
    Interesting light!
    But kind ob huge for 400lm.
    Put-er together-er
    Sep 2018
    Whoa that is a nice looking light! What does the beam pattern look like? It's hard to tell from the video... I like the glass protruding front the front, should help side visibility. Does this work with the ubiquitous MS connector and battery packs? I'm looking to start commuting and would like a high- or helmet-mounted red light, but I'm afraid to ask what this costs...
    Also, I used to live in Lakewood right on GM, which looks like your backyard!
  1. FS: Amoeba Light system
    By farfromovin in forum Classifieds
    Last Post: 04-14-2018, 07:39 PM
  2. Found another use for my Amoeba light
    By scar in forum Lights DIY - Do It Yourself
    Last Post: 09-19-2016, 10:33 PM
  3. Amoeba helmet light on a POC helmet
    By scar in forum Lights and Night Riding
    Last Post: 04-30-2015, 01:46 PM
  4. amoeba light
    By Scottay5150 in forum Colorado - Front Range
    Last Post: 07-11-2011, 07:21 PM
  5. The Amoeba - The simplest "light" form
    Last Post: 05-29-2007, 08:51 AM
