30mm stainless steel bolts?- Mtbr.com
Results 1 to 3 of 3
    New question here. 30mm stainless steel bolts?
    looking for a place to get some bolts,nuts and washers that are at leasts that long but super thin in diameter About1-3m shaft diameter. Its for the 4 bolts hat hold my housing together on my light and the need to be h2o proof. Any online place one might suggest?
    thanks
    Spanish biker
    Reputation: msxtr's Avatar
    Hi, I think that in anywere hardware store ( ironmonger's shop) you found this material.
    Greetings - Saludos
    msxtr
    Warning!!! my english is very very bad, sorry.
    Easy DIY led light1
    Easy DIY led light2
    The Beast!!!
    Reputation: dnlwthrn's Avatar
    Try McMaster-Carr: www.mcmaster.com
    We use them for hardware here at work all the time. I'm pretty sure anyone with a CC can order from them.
    Good luck!
