2s3p configuration help please- Mtbr.com
Results 1 to 11 of 11
    hi all
    need a wee bit of help long story short i.ve built a new mc-e bike light and want to use a 7.4 v 6mah battery pack from a cannon camcorder i,ve stripped the cells out and the pcb from the hard case without taking a lot of notice it was wired 2s3p so i want to rebuild it the same way can some one do me an diagram please. i know i should of taken more notice.there is a b+ / b- and comm? solder points.
    thwang
    is this right as for the PCB the part number is BKD-SBL220/BP930 V4.0?
    Reputation: HEY HEY ITS HENDO's Avatar
    turn the last 3 batteries 180 degrees
    connect them together as the first 3 and to b -
    daisy chain a link on the bottom of the 6 batteries
    .what is the `driver`?
    ...Scun.thorpe, UK
    can you be more specific on the driver ....
    i searched, no results!
    was it in the battery pack you stripped?
    ...Scun.thorpe, UK
    hi
    the battery is from a Canon BP945 which is 6 18500s ive goggled the pcb and found nothing?
    simon
    is it from the battery pack?
    if so, its a protection device for the batteries, and not a led driver
    ...Scun.thorpe, UK
    oops sorry it is a pcb very early start this morning 5.00 am
    simon
    hi hendo
    this is the pcb it has p+/p- b+/b- and comm
    simon
    here is another 2s cell protection circuit
    your wiring diagram is correct
    P- and P+ are the supply leads for your LEDs / driver etc
    ...Scun.thorpe, UK
    hi
    cant see the picture?
    simon
    ...Scun.thorpe, UK
    Lets RIDE!
    Reputation: Jim Z in VT's Avatar
    I'd guess B+/- are the battery contacts, so P must be the output, as Hendo said.
    JZ
    It's not about speed, it's about lack of control.
