18650 cell holder for a MS light- Mtbr.com
Results 1 to 15 of 15
    Does the pcb in a protected 18650 cell do the same thing as pcb in a DIY cell holders like this:
    http://www.batteryspace.com/Battery-...ong-20AWG.aspx
    Is one preferable to the other for any particular reason?
    This seems to be a good reason to pick up that particular battery holder over some of the others which lack a pcb, although I worry about the quality of this one a little. This would allow me to run a slightly higher capacity unprotected cell, right?
    Iím also looking for a charger for the cells. Are there any recommendations? Iíd ideally like to charge 4 at a time, if possible.
    Iím planning on running the magic shine 900 and have the ability to concurrently run the tail light.
    Thanks for your help!
    Chris
    Reputation: Ofroad'bent's Avatar
    Is there any reason we can't solder up our own battery packs from protected 18650 cells?
    I'm thinking just soldering to the contacts of the battery, heat-shrinking then dunking in plasti-dip.
    I'm hoping you'd end up with something waterproof and simple like this:
    https://www.batteryspace.com/li-ion1...ofcoating.aspx
    or this
    without the horrendous shipping charge and the $25 hazmat shipping fee.
    Please shoot this down if:
    - you can't solder to battery contacts for some reason- wrong metal, too much heat
    - the protection isn't enough
    - you can't charge these through the same wires as you discharge for some reason
    - you have to add *** protection pcb. (which you order from ***)
    Bigger is better!
    May 2005
    Quote Originally Posted by Ofroad'bent
    If the batteries have solder tabs, you can do this. Otherwise it's a no-no.
    A much better solution is to buy a 18650 holder for the number of batteries you need.
    Quote Originally Posted by langen
    I assume it would be harder to waterproof the holder,and it would be bulkier.
    Anybody know where to get protected 18650s with solder tabs?
    Candlestick Maker
    Reputation: baker's Avatar
    batteryspace.com
    http://www.batteryspace.com/18650ser...apankorea.aspx
    Tabs as a 25 cent option.
    baker
    With the right iron (high wattage) and good soldering practices, there's no danger in soldering directly to the ends of the cells. I use a 25 watt fat tipped Weller soldering iron, and with the ends of the cells tinned (about 2-3 seconds of contact) and the wires tinned, I can attach the wire with only about another 1-2 seconds of contact. These 2 processes are also timed in such a way that the cell has fully cooled between heat applications.
    Quote Originally Posted by BlownCivic
    OK, now part 2- how about protecting the cells- which of these would work for a 2-cell system, and which for a 4-cell 7.4v system?
    http://www.batteryspace.com/pcmforli...terypacks.aspx
    Alternatively, are "protected" cells sufficient?
    Candlestick Maker
    Conceptually, I like this one, that does post charging equalization:
    http://www.batteryspace.com/pcmwithe...02s20-265.aspx
    I'm not a big fan of the price, though.
    I don't know about wiring protected cells into a pack and then protecting them again with another circuit...
    Whatever board you get, make sure it handles however many amps you plan to draw. I think just about any of the 7.4V ones listed at batteryspace will easily cover your MS amp draw. The 3.0 amp one doesn't have great reviews and is also listed strangely (probably a typo) at 8.7v.
    Personally, after perusing the batteryspace way too much lately, I'm interesting in these LmMnNi cells:
    http://www.batteryspace.com/limnnire...ated148wh.aspx
    And this prebuilt, protected pack looks awesome for a long runtime option:
    http://www.batteryspace.com/LiMnNi-2...-with-PCB.aspx
    baker
    A waste of time it is is
    Reputation: emu26's Avatar
    The problem I see with that last one is that they are protected cells and whilst protected from over discharge / charge the cells will never be properly balanced. I'm not sure if that is an issue with that type of battery, I've actually never heard of them before, but given they are Li based I would guess best practice would be to balance the cells, at least periodically.
    M8 M12 M15 deez nuts
    Yep, same here. I also put a small dab of flux on the wire before soldering it to the end of the cell, it seems to do an even better job.
    Donít frail and blow if youíre going to Braille and Flow.
    Quote Originally Posted by baker
    This is what I'm wondering about. Is there any problem with using a pack pcb along with protected cells? Do you only need one or the other?
    I looked at some of the pack pcbs as well as what protection cells offer and it seems like there are some differences.
    In the description of the individually protected cells, it seems that most don't offer any protection against short circuit while the pcbs on the packs do. Is this a big concern?
    Do It Yourself
    Reputation: Homebrew's Avatar
    There is no hazmat fee at Battery Space for the LG 18650 cells I just bought last week. I'm wiring up a custom pack for a Magicshine this week some time, I'll try to takes some pics.
    Long Live Long Rides
    Quote Originally Posted by Homebrew
    Thanks, following with interest.
    (Who am I kidding- I have 2 decent battery packs, I'm just thinking ahead.)
    A simple solution would be to buy the 2p2s 18650 holder + high capacity unprotected 18650 cells + 2 slot charger. This way the cells will be always balanced and the battery pack will have a higher capacity than stock MS.
    Only problem - waterproofing.
    CNC LED light housing for DIY projects
    Small addition.
    If you use holder like post #1
    or similar on ebay and see this problem:
    "After insert battery(ies), must connect to charger to enable the pcb. Otherwise, you will get "no" output from pcb!"
    You can fix it!
    ?ttp://fotkidepo.ru/?id=album:39613
    Simply add on PCB R4 (smd 0603 2,2 MOhm)
    You can try and make decision.
    (can't add link, sorry)
