14.8V battery & a soldering iron- Mtbr.com
Results 1 to 3 of 3
    What next?
    I have:
    1.A perfectly fine P7 running at 3.7V/1.4-2.8 amps for my helmet.(thanks Doug)
    2.A L&M HID with a dying battery.
    3. A deconstucted "ugly" 3X P4 light. The middle LED in a series string no longer emits? I didn't think that was possible. This made a 1Amp wired buckpuck available.
    Some 1"OD alu round tubing, a 1 Amp buckpuck, and some 1" square tubing.
    I know I could buy something premade but I want to have some fun. So I'm willing to star with the battery and work forwrd. What would you do?
    Triple XPG? w/optics? Single Quazzle? XLM at 1000mA? MCE might require more Volts?
    I'm open to suggestions.
    A waste of time it is is
    Reputation: emu26's Avatar
    Helmet or bar light?
    Just saw that you have a perfectly fine helmet light so would go with a 20mm triple xpg in the 1"OD tube using either the quazzle board or the 1A buckpuck you already have.
    Bar. Batteries in bottle cage.
