12v Battery Options- Mtbr.com
Results 1 to 2 of 2
    Sep 2017
    12v Battery Options
    So I have a project I'm planning on my '74 Schwinn. It involves removing the halogen front & rear lights and replacing them with LED units.
    The units are Dual Intensity and here are the specs:
    • OUTPUT INTENSITY: 1000lm (raw; max.) 600lm (raw; dimmed intensity)
    • DUAL-INTENSITY LED: 1x CREE XML-2
    • DUAL INTENSITY CURRENT: 160mA (dim) 580mA (bright)
    • VOLTAGE RANGE: 9-30V DC
    • MATERIAL: CNC 6061 AL
    • FINISH: Anodized Black
    • WATERPROOF: Yes
    Goals are to put 2 in the front light housing and maybe one more under the seat with a red lens. I'm not yet sure how I'd like to wire them up but I'll figure something out. Rechargeable is obviously a priority and I don't need these lights to last a crazy long amount. I'd just like to have a couple hours if the sun starts to go down early. (Note- This bike will not be on the main roads. Mainly paved parks & around the neighborhood)
    I'd love to be able to gut the original generator that came on the bike and fit a battery pack but the more I research the less that it seems likely there is enough space inside.. If that's the case I'm fine mounting a battery pack somewhere else on the bike.
    Ideally I could purchase something from Amazon as I have a gift card balance. Correct me if I'm wrong here but something like these would work:
    Any help you guys can provide would be appreciated!
    Photos:
    http://i.imgur.com/aaUr78U.jpg
    http://i.imgur.com/llmIe4k.jpg
    http://i.imgur.com/RKkxzB2.jpg
    http://i.imgur.com/Pk4dNpI.jpg
    http://i.imgur.com/kE6kNuJ.jpg
    http://i.imgur.com/5nbFDCd.jpg
    http://i.imgur.com/rviUbKd.jpg
    http://i.imgur.com/ECXXJBV.jpg
    May 2005
    Seems like it should work with the Amazon battery pack if the voltage spec of the light (9-30) is accurate.
    GoPro adapters for bike lights http://www.pacifier.com/~kevinb/index.html
  1. Replies: 24
    Last Post: 12-20-2018, 12:42 PM
  2. Bike Trailer 12V LiPO Battery System
    By Gawain Tomlinson in forum Cargo Bikes
    Last Post: 12-06-2018, 03:10 AM
  3. 12v LED tail light project
    By thebronze in forum Lights DIY - Do It Yourself
    Last Post: 01-19-2011, 05:53 PM
  4. Can a bflex 3xcree run on a 12v sla battery?
    By biketavioumaximus in forum Lights DIY - Do It Yourself
    Last Post: 09-08-2008, 05:31 PM
  5. 12v, 4000 mah Ni-MH battery w/ charger $30
    By iamnate in forum Where are the Best Deals?
    Last Post: 03-30-2004, 03:16 PM
