Results 1 to 5 of 5
    Second set of shock mount holes on Dawg?
    How is the suspension affected if you mount the shock to the rear set of holes on the new Dawg frame? I think most of the Kona lineup (Kikapu, Coiler,....) has the second set but there's no mention of the usage that I can find.
    Also - Why why why ain't there any geometry charts on the Kona website!?!!?
    Reputation: Gazz's Avatar
    Quote Originally Posted by Fixeyfreeride
    The rear hole makes the suspension more progressive, I believe - front hole is more linear (or is it the other way around?)
    For geometry, I think you have to download the catalogue. It's a real PITA, for sure.
    Reputation: Joe - Kona's Avatar
    The rear is progressive, the front linear.
    We're getting the geometry online for each model within the next bit. We're adding and changing a lot to our website right now, so bear with us.
    Joe.
    Awesome.
    Thanks for the help - I'll try out the progressive setting tomorrow.
    Just roll it......
    Reputation: ebxtreme's Avatar
    Yep, the one in the back is better if you're bottoming out a bunch.
    The front one will give you a more linear feel and more supple throughout the stroke, but bottoms easier. I run both bikes with the shock mounted at the rear hole....much better for landing drops, etc.
    EB
  1. Service Tip for all Cane Creek rear shock owners
    By TeamTwentyFour in forum Shocks and Suspension
    Last Post: 06-13-2006, 01:23 PM
  2. Dawg top shock mount bolt broke...
    By rob in forum Kona
    Last Post: 05-23-2004, 07:40 PM
  3. Help me set up Fox Float RL rear shock
    By Mandrake in forum Shocks and Suspension
    Last Post: 04-12-2004, 10:30 AM
  4. K2 Razorback Noleen Mega Air rear
    By MegaVolt in forum Shocks and Suspension
    Last Post: 03-30-2004, 09:28 PM
