    you cant handle bars.
    Dec 2004
    need some help kona heads...
    i recently got a used 99 kona stinky deelux, but its missing some parts. but i now have the chance to buy a complete 01 stinky primo.. is there any real differences between the two bikes, strength or travel wise that i should take into account?
    Deadhead
    Get the Primo if you can swing it. The Primo uses stronger tubing than the older model among other small changes that make it a better choice. Do a google search for "kona.dk". They have an archive of all the older Kona models as well as a forum that may have some more useful info. Good Luck.
    "If you can get both wheels sliding with no brakes, that's when you really know that you're cookin." Nathan Rennie
    Go with the 01 DeeLux !!!
    I had a 01 Primo and its the same frame , great bike , can be used for everything.
    The 01s has the straight seattube as opposed to the earlier Stinkys so U can raise the seat for climbing/cruising and lower it all the way for going down.
    Check them out at www.kona.dk
    Cheers
    Dec 2004
    thanks guys. i actually found out that its got a 01 stinky component set, but its an 02 primo frame (warranty replacment), so i get the killer red/white paint job and 6" of travel. now the choice becomes 99 marz jr-t fork or the 01 marz z1 sc
  1. Need help in restoring an old Ti Kona
    By fishy in forum Kona
    Last Post: 12-04-2005, 07:47 AM
  2. Kona Kula Primo or Kona Explosive?
    By ADDICT in forum Kona
    Last Post: 07-26-2004, 05:58 PM
  3. 2004 Specialized Hardrock Comp vs. 2004 Kona Cinder Cone: Help Me Decide
    By Strategery in forum Bike and Frame discussion
    Last Post: 07-11-2004, 08:54 AM
  4. Frustrated with Kona LBS
    By BAlGaInTl in forum Kona
    Last Post: 07-07-2004, 10:24 PM
  5. Kona Official Supplier of Whistler Mountain Bike Park
    By CraigH in forum Downhill - Freeride
    Last Post: 01-29-2004, 08:00 PM
