Results 1 to 8 of 8
    Dec 2012
    Max Tire Width On A 2018 Kona Explosif
    I'm considering a closeout steel frame 2018 Kona Explosif and would like to know the widest rear tire the frame will fit with reasonable clearance for mud, The original plan was to buy a 27.5+ bike but the Kona caught my interest with great specs for the price.
    Reputation: Timothy G. Parrish's Avatar
    Apr 2014
    There was a thread on the Explosif in the 27.5 forum where this was discussed,I think.
    Apr 2014
    Reputation: LyNx's Avatar
    From the looks of it on this video it seems like it has pretty good clearance running normal tyres, not sure about if it would fit anything over 2.6". Jenson has them in stock and on sale, so should be able to give you a better idea if you give them a call. Can tell you that the Unit has loads of clearance for up to 3" rubber, either B+ or 29+.
    Dec 2012
    Yes, The Jenson deal is what Iím looking at.
    Reputation: Dogboy's Avatar
    Most 2.3" tires can fit with reasonable clearance for mud, etc. Most 2.4" tires fit but you give up some clearance. I wouldn't run anything bigger than that.
    Mar 2012
    I have a 2.5" aggressor on a 33i rim on the back of mine with the dropouts slammed as short as they will go.
    Probably not enough mud clearance with this setup, I'd stick to a 2.4" if you are planning on riding in the mud frequently.
    Apr 2014
    And, FWIW, not all tire sizes are the same between manufacturers. For example, a Michelin 2.35 is equivalent to a Maxxis 2.5. So it will be dependent upon brand AND size.
  1. 2018 Kona Honzo ST max tire size?
    By Blatant in forum Kona
    Last Post: 4 Weeks Ago, 06:04 AM
  2. Replies: 3
    Last Post: 12-07-2018, 03:36 AM
  3. Max reasonable tire width for 25mm inner rim width?
    By noobbiker888 in forum Wheels and Tires
    Last Post: 07-31-2015, 06:21 PM
  4. BFL max height/max width on a 100 rim
    By NOBBY605 in forum Fat bikes
    Last Post: 10-23-2011, 05:28 PM
Members who have read this thread: 18
