Thread: To Joe - Kona
    Dec 2004
    To Joe - Kona
    I asked the question on wheel-forum but was advised to try here and ask Joe. So it is: I own a Stinky 2004 with JrT front and want to change the rear wheel to a 24` wheel with a fat tire. I guess the biggest one I can put for 26` is 2.7 but even 2.5 NBX leaves little clearance now. What do U think of this idea? Won`t this change geometry too much? Has anybody tried it already? I`ll be grateful for any reasonable ideas. I`m going to put a 3.0 rear tire. How about stays then? Will the frame be fine with changed geometry? I already have Jr.T (170mm instead of 150).
    Cheers
    Dec 2004
    I tried an Intense Intruder 2.5 on my 2004 Coiler and found that the chain rubbed on the tyre when in the lower gears, you may be ok with just having a double chainset though.
    Reputation: Joe - Kona's Avatar
    Andy,
    Yeah, a 24" wheel is going to change the geometry. A good number of people have done it and been happy with it, so i see no problems there.
    I can't really say how big a tire you can fit, different companies all measure their tires differently. 3.0" may be a strech, but i've seen some pretty fat 24's out there so you should ahve a good range of choices. Ask around on here, and check with your local dealer. They'll probably let you fit a couple to see if they work before buying them.
    Thanks,
    Joe.
    Dec 2004
    Quote Originally Posted by Joe - Kona
    Andy,
    Thanks,
    Joe.
    Thanks for reply. I`m going to put a 3.0 Nokian Gazza plus Double Wide. I want to build a strong wheel that`s why I decided on these stuff. I hope it`ll be fine.
    cheers
    Andy
  1. Joe -Kona ??
    By forester in forum Kona
    Last Post: 11-16-2004, 01:54 PM
  2. Q for Kona Joe (repost)
    By Mattr in forum Kona
    Last Post: 11-03-2004, 03:13 PM
  3. Joe Kona
    By mtnbkrdr98 in forum Kona
    Last Post: 08-24-2004, 02:48 PM
  4. Joe, can Kona supply...
    By DiRt DeViL in forum Kona
    Last Post: 08-20-2004, 11:37 AM
  5. Joe Kona I Need Your Help
    By Cwilly006 in forum Kona
    Last Post: 07-16-2004, 09:44 AM
