Results 1 to 3 of 3
    Reputation: psmithm's Avatar
    Caution;  Merge;  Workers Ahead! Help: Where the 30.0mm SETBACK seatposts?
    Kona riders, where the 30.0mm SETBACK seatposts? In particular, in a 400 or 410 (even 380) length? I need the setback but I can't find a single one by ANY manufacturer out there... is a shim my only option? Thanks!
    inner peace to make peace
    Reputation: TrailNut's Avatar
    got $195? http://www.boldprecision.com/bicycle.htm
    then you can order a custom titanium tapered setback seatpost from albert bold precision
    i got my custom Bold 30mm-setback titanium tapered (320x27.0mm) seatpost for $193, with shipping: I like it. No doubt you can order a 30mm wide seatpost to whatever setback you specify.
    “Everyday is a good day,” from the Blue Cliff Records, Yun-men (864-949 AD).
    Deadhead
    The only one I'm aware of is the Thomson Masterpiece. It's pricey though at around $130. The Race Face Diabolous post comes in 30.0 and has fairly set back clamp. It's beefy enough you could get away with running the seat further back than normal without risking a busted clamp.
    "If you can get both wheels sliding with no brakes, that's when you really know that you're cookin." Nathan Rennie
  1. where are the 30.0mm seatposts?
    By mtndawg in forum Kona
    Last Post: 01-04-2005, 06:39 PM
  2. Upgrading stems, bars, and seatposts
    By bajoeyt in forum Beginner's Corner
    Last Post: 10-27-2004, 11:40 AM
  3. setback seatpost
    By 04Stumpy in forum General Discussion
    Last Post: 07-04-2004, 05:00 PM
  4. x5 sizing, setback or no setback seatpost?
    By SinglePivot in forum Ventana
    Last Post: 01-13-2004, 03:09 PM
